Hello, I'm to edit this nut model https://we.tl/t-mzwLwggmdD, but when I export the stl file, the threads disappear. Tried recreating threads but could not find the v-thread option.
Thread:
Pitch: 2.17 mm, minor diameter 17.3 mm
OS: Windows 10 Version 2009
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Inner Thread on FreeCad 0.2
- papyblaise
Re: Inner Thread on FreeCad 0.2
you surely did not export "Cut"
- dremel_nut.FCStd
- (119.21 KiB) Downloaded 19 times
- dremel_nut-BodySubtractiveHelix.stl
- (157.41 KiB) Downloaded 21 times
Can you find a more annoying site to put your videos on? That one ust isn't annoying enough.
Select Cut and only cut.
Exported STL in Blender:
The screencast didn't record the menu selections, but from what I can see it looks correct.
Edit: I have to correct myself, the selection is hardly visible here too. drmacro is right. If you select all features, then you close all pockets and cuts.
ok I got it thanks for the help
- Shalmeneser
IMHO, it's weird here to use Part wb and PartDesign wb.
