Surface filling with many edges
NewJoker
Post by NewJoker »
I have a sketch with many edges (created by downgrading the surface of a gear model imported to FreeCAD in step format). It’s a closed profile and I’d like to fill it with a planar surface. I know there’s a Surface Filling tool in the Surface workbench but it wants me to add edges one by one which would take too long in this case. Is there a way to select them all at once or maybe I could use a different tool to achieve my goal ?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
Re: Surface filling with many edges
Use Part MakeFace.
What is it what you finally want to achieve? Can't you use the downgraded wire directly?
NewJoker
Post by NewJoker »
chrisb wrote: Thu Sep 23, 2021 9:03 pm Use Part MakeFace.
Thank you very much, this tool works just as expected. What I need is a surface that can be exported to external FEA software. Basically, I want to perform a 2D analysis on a geometry obtained directly from the 3D model.
I have just tried the following:
0) preliminary step: created a gear with FCGear and exported as step
1) imported the step file
2) Draft->downgrade
3) remove all unwanted faces
-> Finally I am left with the face of interest. This seems to be already what you need.
drmacro
Post by drmacro »
Couldn't you just Draft downgrade the result of FCGear?
My beginners, written treatise: Learning FreeCAD
TheMarkster
Post by TheMarkster »
You can probably use Draft upgrade to upgrade the closed wire to a face, too. You can upgrade edges to a wire if they're connected, then upgrade that wire to a face.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
