Unable to disable leader line auto horiztonal
ggarner
Post by ggarner »
Despite having it turned off in preferences, I cannot disable it when I create new leader lines. Also, I would like a 30 degree snap on leader lines if possible; currently the options are every 45/2 degrees.
chennes
Re: Unable to disable leader line auto horiztonal
Post by chennes »
Could you please post your version information? Thanks.
Chris Hennes
Pioneer Library System
ggarner wrote: Thu Sep 23, 2021 4:39 pm Despite having it turned off in preferences, I cannot disable it when I create new leader lines.
Confirmed, the preference does nothing.
Furthermore it should be shown in italics in preferences, because it is (to be precise: should be) only the default initial value.
You probbaly know that you can change the Auto horizontal property in the Data tab and then change the last segment to non horizontal.
I can see here no snapping at all.
OS: macOS 10.16
Version: 0.20.25645 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
ggarner
Post by ggarner »
Yes, but the problem is this is only possible after the line is created. Currently I add a sacrificial segment that I then delete from the data table after I have disabled auto horizontal.
If you hold control, it snaps.
version information:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I can compile FreeCAD myself, but I decided to use the release version because it's more stable.
ggarner wrote: Thu Sep 23, 2021 9:07 pm If you hold control, it snaps.
Thanks, works here too.
I have added the control key to the documentation of TechDraw LeaderLine.
