I have a simple pocket path but leadin and ramp dressups are greyed out.
Is that expected , if so why?
I don't see any obvious conflict. Why is this not possible ?
Thanks
OS: Fedora 34 (Thirty Four) (LXQt//usr/share/xsessions/lxqt)
Version: 0.20.24847 (Git)
Hash: 20e756306d9aa624fcbf465f0345d721673ce720
Python version: 3.9.4
Qt version: 5.15.2
OCC version: 7.5.0
No ramp dressup on pocket path [FIXED]
- selector.png (9.79 KiB) Viewed 1568 times
Re: No ramp dressup on pocket path
It would be helpful to include the file, but I created a similar one and tested.
I tried all sorts of ramp angles and ramp methods and never saw any sort of failure.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I note that you are using a very new version of python. It is possible there has been some change that does not allow the Ramp to work correctly. Python developers are among the worst on the planet for making things obsolete.
Gene
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Gene
Thanks Gene, nothing was failing, the lead in and ramp dressups were greyed out on the menu.
- selector.FCStd
- (37.14 KiB) Downloaded 31 times
OK, the ramp menu item shows up in full color and the default ramp works correctly. Looks just fine.
Hard to say what might be happening in your testing.
Gene
Gene
looks like finger trouble.
Thanks for taking a look.
Reset Config?
Re: No ramp dressup on pocket path [FIXED]
I realised that I had selected the Pocket and rather than the Pocket_Shape (ie path ) before trying to apply the ramp dressup.
What confused me was that all the other items in the Path Dressup menu were active and only leadin and ramp were greyed out. This made it look like I was in a valid context and only these dressups were not available for some reason.
In fact all the others fail when you try to apply them but are not greyed out. Had they all been greyed out, I would probably have realised my error straight away.
The interface should be consistent.
