Problem with techdraw
Pier Tilma
Post by Pier Tilma »
september 23, 2021
System : Linux Ubuntu 20.04
Freecad : 0.19
I am trying to create an A4 with some technical information (techdraw).
This is what I am doing :
1 - select e.g. front view of a part
2 - go to the already created A4 template page
3 - select that part in the model tree
4 - press button "Insert a view"
Now I.ve get the message :
"Wrong selection - No Shapes, Groups or Links in this selection"
What am I doing wrong ?
Pier
M4x
Re: Problem with techdraw
Post by M4x »
Sounds like a small thing. Could you share a screencast?
Does it work with a default cube from Part workbench?
TheMarkster
Post by TheMarkster »
Don't select the page in the tree view as that will deselect the object. Just select the object and use the insert view tool.
Edit: if you have more than one page select it in the mdi view tab.
Pier Tilma
September 24, 2021
What I did :
1 - Open an existing design in FreeCAD
2 - button "create a new empty document" (techdraw)
3 - button "Insert page using template" (techdraw)
4 - select a body in model tree
5 - press "insert a view" (techdraw)
FreeCAD returns message "Wrong selection No Shapes, Groups or Links in this selection"
What I do now :
2 - button "Insert page using template" (techdraw)
3 - select a body in model tree
4 - press "insert a view" (techdraw)
And this is working
Thanks for your help.
Regards
Pier Tilma
M4x
Post by M4x »
I'm not able to reproduce your issue.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Peek 2021-09-25 13-05.gif (338.22 KiB) Viewed 1662 times
