Please help total nooby
Hello everyone, complete beginner here looking for some help. Recently got into the world of 3d printing and I'm wanting to print out this skull but I wanted to add some teeth to it, how do I get the teeth 3d model over the top of the skull to make it into one model? Hope this question makes sense lol.
- wtf am i doing.PNG (219.18 KiB) Viewed 528 times
Re: Please help total nooby
Hi and welcome to the forum!
Depending on what your input format is, FreeCAD may not be the optimal tool for such organic shapes. Blender may be more suitable.
If they are good meshes it might be possible to do this in Mesh Design. Or it might fail. Hard to say without the file to experiment with.
Create a cube primitive, size and position it to the mask with teeth such that it encompasses only the bits you want to transfer to the other mesh.
The cube can be sized in the properties in the data tab of the property view. It can be positioned either by editing the placement property or right click on it in the tree view, select transform, and use the dragger tool.
Do a boolean intersection with the cube and the mask with teeth. The result of this will be only the bits where the cube and the mask with teeth coincide.
Use the same cube, positioned appropriately, but not resized to do a boolean cut (difference) with the other mask to make a hole where you want to put the teeth.
Position the intersection with the cut and do a boolean union to fuse them together.
If the masks are not near enough the same size you can scale one of them.
You might need to install the OpenSCAD binary. I think Mesh Design booleans sometimes use it.
