[Solved-workaround] TD Image - relative path to image-file?
M4x
Post by M4x »
Hey everybody,
I'd like to put an png-image (screenshot) into a TechDraw document. This is working great via TechDraw_Image. But the image isn't a part of the FreeCAD-project or something like that. Instead TechDraw_Image relies on an absolute path to the image file. This isn't very practical if you're thinking about sharing your project (which I'm currently preparing for).
Is there a way to feed TechDraw_Image with a relative path to the image file? I've tried something like "../pictures/example_screenshot.png" but that didn't work out ;)
I've attached an example project to this post (it's a zip-file because the screenshots and folder structure is provided too).
object tree with (part of) path to image
Snip macro screenshot-da73cf.png (63.81 KiB) Viewed 1029 times
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
example_TD_image_M4x.zip
(28.6 KiB) Downloaded 18 times
Shalmeneser
Re: TD Image - relative path to image-file?
Post by Shalmeneser »
Same problem.
I don't have /home/max/Nextcloud/Documents/FreeCAD/Forum/example_TD_image_M4x/example_screenshot.png in my computer :lol:
Modifying the name doesn't seem to help.
Proposition :
* Explain this problem in the wiki
* Modify absolute name to relative name.
Actual solution :
* Put your png in a svg file. SVG file are incorporated, not linked like png.
M4x
Post by M4x »
Are you kidding me? That's an awesome path :lol: Nevertheless, it should work after adapting the path to the png-file. It does on my system.
Converting it into an svg is an interesting idea. I'll try that.
GeneFC
Post by GeneFC »
Can you bring the file into the Image WB first? Then it will be part of the FCStd document permanently.
Insert the image into a TechDraw page the same way as any other object is inserted.
Gene
M4x
Post by M4x »
The svg-workaround is looking good.
The workaround using the Image_Workbench sounds interesting too but I'm not able to get it to work. Importing the png-file isn't a problem. But I'm not able to add it to a TechDraw page. I've tried TechDraw_View, TechDraw_ActiveView and even TechDraw_Image.
GeneFC
Post by GeneFC »
M4x wrote: Mon Sep 27, 2021 6:37 am I'm not able to get it to work.
You are correct. :oops:
I thought I had used this, but I cannot make it work.
Gene
M4x
Post by M4x »
Alright, it wasn't me than :mrgreen:
