Cut through a plane ...
NHSA_Rainer
Post by NHSA_Rainer »
... in order to see the tolerances between 2 threads ...
As some know I need t draw peices with threads and then 3D print them. In order to see the tolerances between Male / Female threads I would need to look at them and I have seen in Fusion 360 it is quite simple to define a cut for viewing this but I ahve searched and searched but but not found the command for doing this.
Thanks for helping me finding this command
regards Rainer
Shalmeneser
Re: Cut through a plane ...
Post by Shalmeneser »
drmacro
Post by drmacro »
View>Clipping plane
Lets you adjust the the clipping plane.
My beginners, written treatise: Learning FreeCAD
NHSA_Rainer
Hi Shalmenser and drmacro,
OH :o and thanks a lot. You guys are great. :ugeek:
Just tested it and now just get used to how it works :o
regards Rainer
LHC
Post by LHC »
I really miss the hatching pattern that is applied in Fusion 360 when I am using clipping planes for viewing in Freecad. It just seems to get confusing without them. Anyone know if this feature is being considered or worked on?
TheMarkster
Post by TheMarkster »
You can also in Part workbench take a cross-section, and then hide everything else to see the clearances.
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
