OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I have created a luggage label using the technique described in the ShapeString tutorial. Unfortunately, one of the engraved texts has an incorrect depth. The mobile number has the correct depth of 3mm. Unfortunately, when I made the name engraving I only set the depth to 2mm. I would like it to be 3 also. Changing the Length Fwd parameter of Extrude001 makes no difference. How can I change the depth?
[Solved] Changing engraving depth
- Luggage label.FCStd
- (563.28 KiB) Downloaded 25 times
- papyblaise
Re: Changing engraving depth
it is not smart to have to give your name and your N ° on a forum, you risk to sleep badly the next days
your mistake is in the placement: one is at Z = 2 and the other Z = 3
