When hole depth reaches the other end of the object, the full thin disappears.
Hey, I use version 0.20.
When I set the depth parameter of Hole002 to 30mm (so it would make a hole through all the way), the part disappears.
1, why?
2, why was this not a problem with my other holes?
Thanks!!
1, why?
Thanks!!
- CG tartó.FCStd
- (42.29 KiB) Downloaded 40 times
Re: When hole depth reaches the other end of the object, the full thin disappears.
When I open your file it looks weird, why?
Not sure what weird means to you
But maybe it is due to software version difference.
Sketch is invalid, no T-joins are allowed.
Whats wrong with this picture?
I think it's LS3....
- Shalmeneser
Which FC version ?
Sketch(000) :
* T jonctions are forbidden
* 2 lines at the same place
Sketch m4 :
* support=Face : bad practice (TNP)
* tool PartDesign_Hole needs only circle (or arc), not rectangle (use Sketcher_ToggleConstruction)
Sketch 10es lyuk :
* dimension=0 : bad practice => use Sketcher_ConstrainPointOnObject
Sketch004 :
* twice 4mm : bad practice => use Sketcher_ConstrainEqual
At the end : Refine=true
Sketch(000) :
Sketch m4 :
Sketch 10es lyuk :
Sketch004 :
- CG tartó_SHALM.FCStd
- (49.47 KiB) Downloaded 27 times
