OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I have a cone(see blue cone picture) which is a cylinder running in the middle.
I have designed the cylinder with the correct dimensions(circumference, thickness), but I noticed that the bottom piece of the cone is less thicker than the top bit.
Basically, the bottom piece of the cylinder goes down from the internal side of the cylinder.
How do I reduce the thickness of the bottom portion of the cylinder? Maybe just 20mm
Q2:
The cone(see picture) has another shape attached to it at the bottom.
Do I design this piece separately and then put the 2 pieces together? cylinder + other shape
Is there a tutorial on how to join the 2 pieces?
Cylinder(Cone) Design - some questions
- cone-bottom.jpg (195.47 KiB) Viewed 672 times
- cone.jpg (45.15 KiB) Viewed 672 times
- basic.FCStd
- (12.05 KiB) Downloaded 17 times
- Shalmeneser
Re: Cylinder(Cone) Design - some questions
You should work with PartDesign_Revolution.
- Capture du 2021-10-12 21-50-09.png (74.89 KiB) Viewed 656 times
- Revolution.FCStd
- (18.8 KiB) Downloaded 17 times
Thanks! I will download your freecad file and see how you designed it. Much appreciated
