Is the axis reference option works? how?
OS: Windows 10 (10.0)
Version: 0.20.25943 (Git)
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/France (fr_FR)
array with an axis
array with an axis
- array.FCStd
- (9.62 KiB) Downloaded 21 times
- Capture.JPG (37.94 KiB) Viewed 1004 times
Re: array with an axis
In my opinion this line is only important as a center line for a polar array, It is not used with a orthogonal array, but there is a standard menu lay out for all types of arrays
I don't think it works. Maybe it's for a different type of array or a leftover property from an earlier version or maybe it was broken in all the Draft workbench code changes.
Here's a hack for you. Make the Array attachable and attach it to the edge.
Select the array
Ctrl+Shift+P to send it to the python console as object "obj"
Enter into the console:
Select something else, then select the Array again
Attach to the edge.
Array retains its attachment capabilities after saving/restarting/reloading
Select the array
obj.addExtension("Part::AttachExtensionPython")
Attach to the edge.
The tooltip seems pretty explicit to me.
The property should probably be hidden for ortho arrays.
I should buy new glasses or sleep more. thanks.
