[SOLVED] Calculate Distance Between Cylinder and Line (3D Math Problem)
gbroques
Post by gbroques »
Hi all.
I'm struggling with a 3D math problem and need some help.
The problem is as follows:
  • There's a line in 3D space defined by two points, p1 and p2 (see Front View screenshot).
  • This line represents the bottom edge of a flat metal bar, welded onto a pipe.
  • There's a pipe centered around the origin with a known radius, r (see Top View screenshot) .
  • I want to calculate the distance, x, between the pipe centered around the origin, and the line, so that I know the width of the flat metal bar.
How would I calculate this?
Maybe there's some other solution that would you propose given different known facts?
Using Python code in FreeCAD or describing a solution in terms of mathematics (vectors, planes, etc.) would be great!
Let me know if my question is not clear enough! :)
gbroques
Re: Calculate Distance Between Cylinder and Line (3D Math Problem)
Post by gbroques »
I just wanted to follow up on this and let people know I figured it out.
Given 2 points (or Vectors), P1 and P2.
PNx, PNy, PNz notation is used to describe the x, y, and z components of each point, where N is 1 or 2.
STEP 1
I formed the equation of a 3D line:
Line3D(t) = P1 + t (P2 - P1)
Where t is some scalar between 0 and 1.
STEP 2
Next find a value for t, where z = 0.
t = -P1z / (P2z - P1z)
STEP 3
Finally, use t from above and x-values from points to find the x-coordiate value for the point on the 3D line where z = 0.
(This comes from the equation of the 3D line, but only condsering the x-coordinate.)
x = P1x + t * (P2x - P1x)
STEP 4
In my case this yields a negative x-coordinate value for the point on the line where z = 0.
Take the absolute value this point, and subtract r, to get the distance between the line and cylinder centered about the origin.
d = abs(x) - r
References
mario52
Re: [SOLVED] Calculate Distance Between Cylinder and Line (3D Math Problem)
Post by mario52 »
Hi
then Vector_API
and DraftVecUtils.py "C:\FreeCAD\Mod\Draft\DraftVecUtils.py"
mario
