Fair enough. I will try 0.20 and see if the same fix works.
Crash on Ubuntu 21.10
Re: Crash on Ubuntu 21.10
It turns out that I'm not the first to have this issue. In fact, the weekly builds page (https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds) calls this out specifically and points to this forum thread (https://forum.freecadweb.org/viewtopic. ... 51#p510504) . I have rebuilt my local image and this gets me to a good place until this can be resolved on the build server.csetera wrote: ↑Fri Oct 15, 2021 11:50 amFair enough. I will try 0.20 and see if the same fix works.
- Shalmeneser
Please do not repeat all posts in your text but select only useful ones.
I have the same issue with Ubuntu 22.04 - older , and current weekly appimage:
FreeCAD_weekly-builds-28730-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD_weekly-builds-28774-Linux-Conda_glibc2.12-x86_64.AppImage
Wayland or Xorg, makes no difference.
./FreeCAD_weekly-builds-28774-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.20, Libs: 0.20R28774 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
/tmp/.mount_FreeCA57PZ1n/AppRun: line 42: 23871 Aborted (core dumped) ${MAIN} "$@"
Check the Known OS specific issues.
thank you.. that link could have been compiled into, and displayed as error-handling on start
- adrianinsaval
another odd thing is that my home workstation, same Ubuntu, same Freecad ... works just fine without the variable.
- adrianinsaval
different graphics driver?
yes, you are likely to be right - I have Nvidia proprietary at home, and only Intel (whatever is inside I9-9900) at the office.
