Fillet fails to update
Freecad version:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
After having less than 0 time to play with Freecad for a large amount of time I had a go again a couple of days ago.
I have created a little scoop 4 days ago. During its design I have not gotten errors, and even printed a version.
This evening however I wanted to change the length of the handle, and that is were things started to go weird.
I keep getting an error "failed to create fillet". Even if I now take the original design the first fillet (fillet 1mm) and do a re-calculation it will throw an error.
As said I opened the file I left a couple of days ago and all I did was "recalculate object"without changing a single thing. I have been searching the web and in freecad itself so see if I could find what could cause this, but I do not see what is going wrong. When I select the fillet ( fillet 1mm) then all 3 side show up nice in pink. everything seems to be a single piece, and as said I did not change a thing and did not get an error when I created the fillet nor a couple of other fillets after that.
I hope someone sees what I a doing wrong or what is going wrong
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- meelwormen schepje - V1.FCStd
- (89.06 KiB) Downloaded 47 times
- Shalmeneser
Re: Fillet fails to update
* Open "Fillet 1mm" or 2mm or 5mm
* Close it with OK
* Last fillet fail
I think the problem is with Refine.
I don't know why there is yet a seam line underneath when all fillets are with Refine=true.
You should set Refine=true in the last Pad then correct all fillets (suppress + add).
* Close it with OK
* Last fillet fail
The seam is properly removed here. OS: macOS 10.16Shalmeneser wrote: ↑Fri Oct 15, 2021 9:40 pm I don't know why there is yet a seam line underneath when all fillets are with Refine=true.
Version: 0.20.25943 (Git)
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
- Shalmeneser
Fillet1mm with Refine=true shows seam in the original file.
This seam disapear after opening Fillet1mm and OK it, but after fillet2mm fails.
- Capture du 2021-10-16 00-19-30.png (42.52 KiB) Viewed 2073 times
That's probably due to the topological naming change.
- Shalmeneser
True, but why is the seam still visible with refine=true in the original file ?
That's a riddle to me.Shalmeneser wrote: ↑Sat Oct 16, 2021 8:01 am True, but why is the seam still visible with refine=true in the original file ?
I opened the file and did nothing but changing Refine=True for Fillet 1mm and making it visible. I upload the file in that state, please have a look and check if a recompute shows the seam again.
- meelwormen_refined_cb.FCStd
- (74.94 KiB) Downloaded 33 times
- Shalmeneser
Your file shows directly an under face without seam.
The original file with recompute hide the seam in Fillet1mm.
I thought changing Refine status would recompute the construction, hiding the seam (and failing latter fillets).
BTW, opening your file and rotating it shows weird view, like a cut in the view (picture).
- Capture du 2021-10-16 11-33-50.png (5.18 KiB) Viewed 1879 times
That's what it does here if I leave the fieldShalmeneser wrote: ↑Sat Oct 16, 2021 9:43 am I thought changing Refine status would recompute the construction, hiding the seam (and failing latter fillets).
I don't know if it is in the file or just an unlucky coincidence of the camera position. A "Fit All" should fix this.BTW, opening your file and rotating it shows weird view, like a cut in the view (picture).
Sketch002 uses a zero dimension instead of a point-on-line constraint. When I fixed that problem the seam disappeared. Due to precision issues there really is a small step at that point.Shalmeneser wrote: ↑Sat Oct 16, 2021 8:01 am True, but why is the seam still visible with refine=true in the original file ?
Gene
