Sketcher: Angle constraint name not shown
Re: Sketcher: Angle constraint name not shown
Quick patch something such as https://github.com/FreeCAD/FreeCAD/comp ... 6:patch-33 ?
I thank all of you for your attention to this little bug, and for your efforts!
That should do the trick. Thanks for the patch . Can you submit the PR, but maybe with a more descriptive name?Syres wrote: ↑Sat Oct 16, 2021 11:22 am Quick patch something such as https://github.com/FreeCAD/FreeCAD/comp ... 6:patch-33 ?
Issue fixed by @Syres916 in PR 5115. However, I'm gonna add a little feature request here: for small enough angles, the constraint text can get really crowded (see attached picture). If it would be possible to move the text outside of the two bars showing the angles, that would be great.
What commit is this in?
Doesn't appear to be in 26160...for any constraint.
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26160 (Git)
Hash: cf1a0f759811ca1ffa71a2b122b12687d36826ae
Python version: 3.7.3
Qt version: 5.11.3
Qt version: 5.11.3
PR hasn't been merged yet so @jnxd must have either manually tweaked the source locally or pulled the PR branch, it's only two lines to change for you to change it manually and recompile. On Windows 7 for the dimensional constraints to activate I have to close the Sketch and re-open but on Linux Mint 19.3 the change works with the sketch open but there's no way I'm classing that as an issue.
Actually I did find the setting in Preferences. And is does work for everything but angles.Syres wrote: ↑Tue Oct 19, 2021 3:20 pmPR hasn't been merged yet so @jnxd must have either manually tweaked the source locally or pulled the PR branch, it's only two lines to change for you to change it manually and recompile. On Windows 7 for the dimensional constraints to activate I have to close the Sketch and re-open but on Linux Mint 19.3 the change works with the sketch open but there's no way I'm classing that as an issue.
I build daily from git, so I can wait.
- Shalmeneser
