Sketcher: Angle constraint name not shown
Syres
Re: Sketcher: Angle constraint name not shown
Post by Syres »
Olav
Post by Olav »
I thank all of you for your attention to this little bug, and for your efforts!
doia
Post by doia »
Syres wrote: Sat Oct 16, 2021 11:22 am Quick patch something such as https://github.com/FreeCAD/FreeCAD/comp ... 6:patch-33 ?
That should do the trick. Thanks for the patch 🙏 . Can you submit the PR, but maybe with a more descriptive name?
Syres
Post by Syres »
jnxd
Post by jnxd »
Issue fixed by @Syres916 in PR 5115. However, I'm gonna add a little feature request here: for small enough angles, the constraint text can get really crowded (see attached picture). If it would be possible to move the text outside of the two bars showing the angles, that would be great.
Note the limited space for the text "arc_angle_0 = 15"
Screenshot at 2021-10-19 10-21-51.png (38.33 KiB) Viewed 1359 times
drmacro
Post by drmacro »
What commit is this in?
Doesn't appear to be in 26160...for any constraint.
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26160 (Git)
Hash: cf1a0f759811ca1ffa71a2b122b12687d36826ae
Python version: 3.7.3
Qt version: 5.11.3
Syres
Post by Syres »
drmacro wrote: Tue Oct 19, 2021 3:00 pm What commit is this in?
PR hasn't been merged yet so @jnxd must have either manually tweaked the source locally or pulled the PR branch, it's only two lines to change for you to change it manually and recompile. On Windows 7 for the dimensional constraints to activate I have to close the Sketch and re-open but on Linux Mint 19.3 the change works with the sketch open but there's no way I'm classing that as an issue.
drmacro
Post by drmacro »
Syres wrote: Tue Oct 19, 2021 3:20 pm
Actually I did find the setting in Preferences. And is does work for everything but angles.
I build daily from git, so I can wait.
Shalmeneser
Post by Shalmeneser »
jnxd wrote: Tue Oct 19, 2021 2:25 pm If it would be possible to move the text outside of the two bars showing the angles, that would be great.
+1
