Sketcher: Angle constraint name not shown
Olav
Post by Olav »
Hello. I'm very glad with the new setting "Show dimensional constraint name" for the Sketcher WB. However it appears not to work with angle constraints.
In the picture below the name of the angle reference constraint should be (boringly) "angle" but it is not shown.
Any advice? Or should this be considered a bug?
OS: Ubuntu 18.04.6 LTS (XFCE/xubuntu)
Version: 0.20.
Branch: unknown
Hash: 8fceac17628778bd0b2ba4c60bafd6494348ac08
Python version: 3.6.9
Qt version: 5.9.5
OCC version: 7.5.2
Shalmeneser
Re: Sketcher: Angle constraint name not shown
Post by Shalmeneser »
Something forgotten during PR.
Confirmed. Please create a tracker entry.
drmacro
Post by drmacro »
is angle perhaps a reserved word?
(not a pc, can't check...) :?:
Olav
Post by Olav »
chrisb wrote: Fri Oct 15, 2021 10:03 pm Confirmed. Please create a tracker entry.
Thank you. Can you please do it? I'm not really familiar with the bug tracker or its proper procedures.
Olav
Post by Olav »
drmacro wrote: Fri Oct 15, 2021 10:52 pm is angle perhaps a reserved word?
Tried with different names, same result.
doia
Post by doia »
No, I found the error.
On redraw of constraints the angle constrain doesn‘t use the getPresentationString() method, as linear or radial/diameter constraint do. Instead it calls getPresentationValue() directly.
See https://github.com/FreeCAD/FreeCAD/blo ... .cpp#L5769 vs. https://github.com/FreeCAD/FreeCAD/blo ... .cpp#L5465.
doia wrote: Fri Oct 15, 2021 11:19 pm I found the error.
Great! Can you create a pull request? Then I don't have to create a ticket :mrgreen: .
doia
Post by doia »
Unfortunately only in 14 days. Vacation time just started 8-), I will not have any dev equipment with me. Please create a ticket and anyone who can do a quick patch might go ahead.
Steps for a fix IMV are :idea: :
- make angle dimensions use getPresentationString() to render
- in getPresentationString() make an exception for angle dimensions so these don't accidentally use metric/imperial units
- check for any other overlooked dimension string :roll:
- in the long run check if getPresentationString() and getPresentationValue() are not actually the same functionality and can be summarized into a unified function -> are these called anywhere else than in ViewProviderSketch.cpp?
issue #4766. Thanks doia for the detailed proposal.
