Fully constrained sketch no errors but missing hole.
Syres
Re: Fully constrained sketch no errors but missing hole.
Post by Syres »
Shalmeneser wrote: Sat Oct 16, 2021 7:49 pm What's the version of the FC file ?
What's the version of the FC reader ?
The version used to save the file by @drmacro was 0.20R26155 (Git) and I've just proved the lack of backwards compatability using:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Shalmeneser
Post by Shalmeneser »
Syres wrote: Sat Oct 16, 2021 8:07 pm ...
Is it possible to find the version of FC creation inside the file ?
So you think it's not the usual bug ?
Syres
Post by Syres »
Shalmeneser wrote: Sat Oct 16, 2021 8:14 pm Is it possible to find the version of FC creation inside the file ?
You have to extract the FCStd which is actually a zip file (I use 7-Zip) and then open the Document.xml as per screenshot:
It's definitely not a bug as I was heavy involved in the debugging of the 0.20 change to establish why the Occurrences lookup wasn't being triggered though it needed Werner to actually fix it. It's a lack of backwards compatibility, completely different ball game and I've stated the community has never guaranteed it, just like the Blender Foundation doesn't.
Shalmeneser
Syres wrote: Sat Oct 16, 2021 8:24 pm
Thanks for all the infos.
koirat
Post by koirat »
It might not be a BUG than but it might be perceived as one until you give some warnings/messages stating that we are opening file of different version and some incompatibility might occur.
Extraction can also be done with the FreeCAD GUI: Menu->Tools->Project utility.
GeneFC
Post by GeneFC »
koirat wrote: Sat Oct 16, 2021 8:38 pm It might not be a BUG than but it might be perceived as one until you give some warnings/messages stating that we are opening file of different version and some incompatibility might occur.
There was no intentional change in the file structure. This was a bug that has been fixed in version 0.20. How would version 0.19 have any clue about the version 0.20 bug or fix?
There are many new features that do not work in older versions. If the user is creating and opening his or her own files those problems will never be seen.
Gene
papyblaise
Post by papyblaise »
325 constraints is too too too large , the best is Sclm simple barr whith 2 hole , and 2 circular array
koirat
Post by koirat »
papyblaise wrote: Sun Oct 17, 2021 12:18 pm 325 constraints is too too too large , the best is Sclm simple barr whith 2 hole , and 2 circular array
Ok cool I'm a total newcomer when it comes to freecad and my experience with CAD is limited.
But I want to have the shape of spline shaft as a sketch without polar patterns involved, sometimes I'm using it as a hole and sometimes for extrusion, so if you got a better solution I'm very open for modifications.
papyblaise
it's the same : shaft is a rod whith teeths : you do a rod and substract rectangular grove and Array
Hole is the same
