Fully constrained sketch no errors but missing hole.
drmacro
Re: Fully constrained sketch no errors but missing hole.
Post by drmacro »
koirat wrote: Sun Oct 17, 2021 4:17 pm
papyblaise wrote: Sun Oct 17, 2021 12:18 pm 325 constraints is too too too large , the best is Sclm simple barr whith 2 hole , and 2 circular array
Ok cool I'm a total newcomer when it comes to freecad and my experience with CAD is limited.
But I want to have the shape of spline shaft as a sketch without polar patterns involved, sometimes I'm using it as a hole and sometimes for extrusion, so if you got a better solution I'm very open for modifications.
A simple sketch (as I did) works the same in each case. Make the hole, pattern the result. Make the Pad, pattern the result.
BTW, to avoid confusion when talking about these things: in Part Design workbench you Pad, in Part workbench you Extrude. They are similar, but different, and using the word extrude when talking about a Pad can become confusing.
koirat
Post by koirat »
I appreciate all the effort you guys make in making my sketch better.
But can we accept the fact that I want to have this little piece in one piece :).
I want to have it like this for a reasons:
I will carbon copy it to my other sketches. (I'm creating my own sketches library)
I will use its edges to make constraints for other edges.
I don't want to have too much sketches for some bodies, so I'm not going to create additional sketch just to do the pocket.
Theoretically it is possible to make it much more readable by using equality constraints instead of measures but as I have said I could not tame it, a the end of constraining I got this "orange" over-constraining all the time and when I started to delete constraints it broke.
Now if you know the way to do it without array methods I will be glad.
drmacro
Post by drmacro »
koirat wrote: Sun Oct 17, 2021 5:55 pm I appreciate all the effort you guys make in making my sketch better.
IMO, no, not when there is a better approach. ;)
I used CC to make the different size splines.
As can be done with simpler sketches. (and possibly other tools) :?:
I don't understand what this means, you have created 2 sketches, I have created 2 sketches.
If you want to explain the long term goal of your thinking, it may help us understand why you feel the need for more complicated sketches.
Then that is something you need to actually create the issue in a sketch and then start a thread where we can, hopefully, give you pointers on how it can be tamed. One typical cause of over constrained warning is complicated sketches and complicated constraining schemes.
But, arrays are the most efficient way to accomplish the task as I understand it...maybe I don't. As I ask above, explanation of the ultimate goal...
If you prefer your way, then that is enough to say and we need not continue the discussion. We are simply attempting to help you design a more efficient and maintainable model.
papyblaise
Post by papyblaise »
a mini as I can 91contraints :!:
the method as we propose is less and less load
shaft canneled.PNG (66.03 KiB) Viewed 974 times
shaft canneled.FCStd
(12.08 KiB) Downloaded 22 times
koirat wrote: Sun Oct 17, 2021 5:55 pm Theoretically it is possible to make it much more readable by using equality constraints instead of measures but as I have said I could not tame it, a the end of constraining I got this "orange" over-constraining all the time and when I started to delete constraints it broke.
Upload the sketch improved as far as possible with the overconstraint. Then somebody may help you as some sort of exercise.
For real improvements there are enough proposals above from guys who are really eperienced. You should seriously consider their advice.
Shalmeneser
Post by Shalmeneser »
110 constraints. But the theeth are parallels.
Hole_SHALM.FCStd
(11.79 KiB) Downloaded 21 times
Capture du 2021-10-17 21-25-31.png (64.21 KiB) Viewed 929 times
drmacro
Post by drmacro »
Are we having a competition? :mrgreen:
9 edges, 24 constraints...
Snip macro screenshot-a5e1dc.png (66.15 KiB) Viewed 916 times
koirat
Post by koirat »
papyblaise wrote: Sun Oct 17, 2021 6:51 pm a mini as I can 91contraints :!:
Your picture is unfortunately wrong.
Edges should not go into the center.
In the attachement SplineShaft.FCStd there is a body named SplineShaftNew.
It was my attempt at simplifying the sketch.
When you look at the picture, I have selected all those marked arcs and used equality constraint, but the result is not equal.
The second thing is that I cannot move any edge but the sketch is still not considered fully constrained.
SplineShaft.FCStd
(50.35 KiB) Downloaded 19 times
Shalmeneser
koirat wrote: Sun Oct 17, 2021 7:55 pm When you look at the picture, I have selected all those marked arcs and used equality constraint, but the result is not equal.
Equality on arc gives same radius.
To have the same width, you have to use a blue line with same length.
Based on Shalmeneser's approach I could reduce the number of constraints to 95.
Please note that I would not recommend to model this way, because it is not very clear. It is just to be seen as an exercise.
Hole_cb.FCStd
(7.91 KiB) Downloaded 20 times
