Sketch not applied to part body
drmacro
Re: Sketch not applied to part body
Post by drmacro »
csetera wrote: Sat Oct 16, 2021 7:04 pm
drmacro wrote: Sat Oct 16, 2021 6:59 pm Then I simply do not not understand you question. If you convert the holes to geometry rather than reference geometry (and get rid of the 0mm dimensional constraints), it works as expected.
Thanks... I didn't realize I had not toggled back from construction geometry. (see my other response in the thread)
Craig
Yes, well, not having geometry is definitely an issue. :mrgreen:
But, be aware using 0mm dimensional constraints is not a good practice. In fact, it will most likely bite when you least expect. ;)
csetera
Post by csetera »
drmacro wrote: Sat Oct 16, 2021 7:09 pm
I'm assuming you are referring to the places I connected the rectangles to the construction lines? Out of interest, how might that bite me and what is the proper way to accomplish the same thing?
Thanks again,
Craig
drmacro
Post by drmacro »
csetera wrote: Sun Oct 17, 2021 1:08 pm
Thanks again,
Craig
Constrain one vertex to the construction line with constrain point onto object, Image
You should always favour geometric constraints over dimensional constraints. This is because geometrical constraints are less compute intensive.
A 0mm dimensional constraint, won't necessarily maintain horizontal/vertical of the dimensioned edge when the solver solves. This is likely to cause, unexpected results.
Snip macro screenshot-2f3c62.png (7.4 KiB) Viewed 463 times
