Problems overwriting construction lines
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Since I installed this new version I have had a persistent annoyance that overwriting a vertical construction line with a constrained edge inserts the vertical constraint on the new line which conflicts with the vertical constraint on the construction line. I get an error message that there is a redundant constraint - obviously, you don't need both of them. The same applies when overwriting horizontal construction lines. Perhaps you could call this a 'Bug'. It means that I can't do a series of overwrite lines and I have to remove the redundant constraint and restart line-draw each time. That's just a petty time-waster. Is there a fix?
Right now I have a similar problem with this sketch: I am overwriting the construction lines and have stalled here. I need to overwrite the two arcs (red arrows) and the edge between them (between the two green arrows). I get all sorts of redundant constraints when I try. How do I get around this one?
Thanks
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks
- 211017 AP-00-000.FCStd
- (13.24 KiB) Downloaded 34 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: Problems overwriting construction lines
You may have changed your settings. At th eleft side, under "Edit controls" you can check Auto constraints.
At your stage of knowledge I would not recommend to check "Auto remove redundants", because you cannot control which constraint will be removed.
I had 'Auto constraints' checked
but that doesn't change things - I just tried with it unchecked. Note that I can draw in the vertical line (blue arrows)
and I only need to remove the new constraint. The other lines I mentioned create problems."It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
FTR: I fixed the immediate problem by simplifying my sketch. The old story - "If it's complicated it's probably wrong!
However, that leaves the problem with redundant constraints while overwriting."It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
This sketch just begs to be reduced to the top or bottom symmetry and mirrored after padding. Which would simplify the sketch and constraint requirements.
But I'm sure you've thought of that.
- Shalmeneser
Drawing on a constraint arc using [arc center+arc vertex+arc vertex] gives usually redondant constraints.
You need to draw with [arc center+arc vertex+new vertex on a line]. This other vertex can be on a tangent line
Picture example : [arc center+arc vertex+last vertex on the X-axis].
- Capture du 2021-10-17 22-54-49.png (5.9 KiB) Viewed 1947 times
- arc over arc.FCStd
- (12.94 KiB) Downloaded 41 times
Thanks, Shalmeneser, but that's not the issue. The Arc you are overwriting is not constrained so your new arc (drawn unconstrained over the old arc) does not raise a 'redundant constraint' warning. Then when you do constrain the new arc that is the first and only constraint and no warning is required.
If you delete your new arc, then constrain the old arc (set it as a construction line) to 30mm radius and then draw a new arc over the (now) construction line you should get some redundant constraint issues. I did!
Joseph Kimble
Joseph Kimble
If you read my other recent posts it will be clear that I am a proponent of individuals following a style that feels comfortable, not some rigid set of "best practice" rules.
However, I question the style of sketching construction geometries and then retracing exactly over those construction geometries with real geometries. Any time one completely covers an underlying structure there could be issues.
I use construction geometries to outline limits and provide convenient attachment points for real geometries. I almost never trace over and obscure an entire construction feature.
Carry on as you wish, of course. Just offering a commentary.
Gene
Gene
I agree completely. The example Shalmeneser and I are discussing is just that - an example.
Joseph Kimble
Joseph Kimble
Greetings to the Community!
With the (Win8) FC 0.20-25997 (standalone) version no problem.
I attach the file
I attach the file
- (13.68 KiB) Downloaded 34 times
- overwriting_construction_lines.gif (410.77 KiB) Viewed 1741 times
