Best way to start
keltel
Best way to start
Post by keltel »
Hello.
I am new to FreeCAD and recently posted a question about making automatic holes but I guess my overall question is a bit bigger...
I am wanting to make a plate with various gear attached - think similar to an electrical switchboard: a metal plate with fuses, switches, trunking, etc. I have various individual parts available as step files and would like to position them over a metal plate, and at the end be able to produce some 2D drawings from the front and side view. I am having a hard time getting started.
Would I use A2plus or Assembly4 for something like this? I would like to have a grid available during placement of the parts so I can position them appropriately - I can add constraints later if required but I really do need to have a grid while working - like drawing in 2D. Is this possible? I would like to be able to mark up a diagram of the metal plate for someone to be able to drill the right holes, etc. What is the best place to start with this?
TIA. Kel.
Re: Best way to start
If you have gears, the assembly workbenches may not be sufficient for placing them. I would start with a so called master sketch, which defines the important positions. Then you can use e.g. manipulator addon workbench or Draft ->Move with appropriate snaps to place the imported parts.
thomas-neemann
Post by thomas-neemann »
keltel wrote: Mon Oct 18, 2021 2:01 am
I do it like this, without assembly wb
they are step files saved as fcstd
https://www.youtube.com/watch?v=xUSehs8Cgro
phpBB [video]
you can also work with the grid from draft. with this snap function
you can catch it while moving parts
this is how i create 2D drawings because techdraw is still too slow for me
https://forum.freecadweb.org/viewtopic. ... ab#p538390
M4x
Post by M4x »
I think he means gear not gears. You could although say stuff I guess.
Regarding the drawing to make clear which holes go where, you should be totally fine using TechDraw.
keltel
Post by keltel »
Thank you for the texhdraw info - that is perfect!
@chrisb: You say to start with a master sketch. How do you do this? Ideally I would like to do that - have a master sketch on some grid, on top of which i can build extra parts. It would be great to be able to place on top of that sketch (with snap) as a reference.
