What is the optimal workflow for lasercut.
koirat
Post by koirat »
My current workflow looks like that:
I go to the draft and select body/bodies.
Next set view to top and Modification->Shape 2D View.
Next I move all the 2D shapes so they don't intersect also I try to align them to optimize space usage.
Next I select all the shapes and File->Export to dxf
My dreams workflow:
- I can select multiple parts or groups not only Bodies but I will have 2D shape created for every body separately. (currently when i select Part I get 2D shape for the whole part)
- Shapes will not intersect and will be packed relatively tight. (Like automatic UV unwrapping (with islands) in 3d modeling software)
Any Tips ?
drmacro
Re: What is the optimal workflow for lasercut.
Post by drmacro »
My laser uses gcode, so sketch, Path workbench, generate gcode, import gcode to laser control, burn
koirat
Post by koirat »
I don't have a laser cut device and companies want dxf, sometimes they provide online cost calculator that is using dxf format.
So I need dxf In the end, but the question is how fast can I generate it. My current workflow is slow.
drmacro
Post by drmacro »
koirat wrote: Mon Oct 18, 2021 12:45 pm ...
Any Tips ?
You may be expecting too much magic...
:mrgreen:
user1234
Post by user1234 »
https://wiki.freecadweb.org/Arch_Nest
But in real live, the parts are arranged by hand.
koirat wrote: Mon Oct 18, 2021 12:45 pm My dreams workflow
This is a technical forum, so dreams and magic are not relevant here. Ideas or conception are relevant.
Greetings
user1234
koirat
Post by koirat »
Unfortunately ArchNest gives me an error:
Executing conformity tests ... One of the shapes does not contain exactly one face. Aborting
So I guess it will not work for shapes prepared for laser-cut.
drmacro
Post by drmacro »
user1234 wrote: Mon Oct 18, 2021 1:31 pm https://wiki.freecadweb.org/Arch_Nest
Greetings
user1234
As far back as the 1980's there was nesting software for sheet metal manufacturing. They take a list of the shapes to be cut and arrange them so as to minimize waste, required clearance, etc.
I know of nothing like that in FreeCAD, but several software programs do appear in a web search.
But, they probably require 2D geometry files as input.
Path workbench has a dxf postprocessor. Try it and see if your dream has already come true.
koirat
Post by koirat »
chrisb wrote: Wed Oct 20, 2021 6:16 am Path workbench has a dxf postprocessor. Try it and see if your dream has already come true.
I have a macro that is selecting all the visible bodies so I can batch 2DView them, I already made first step to walk a path of my dream.
For now I'm satisfied, experimenting with new workbench right now will harm the time of my work.
skintigh
Post by skintigh »
This website nests your SVGs. But it wants everything to be "children" and it ignored all of my gears... much like every feature in FreeCAD does...
https://svgnest.com/
