I'm learning FreeCad v0.19 on Windows 10 and working through a number of intro videos.
- Using the Parts Workbench and working on the x,y plane I place a "Point" at a random position on the x,y plane.
- Question 1: How do I display the coordinates of that single point (or a point on a shape) in either 2d or 3d space?
- Question 2: How do I relocate the point to a specific location on the x,y plane? Or in 3D space?
Thanks for any help.
How to see coordinates of and/or move a Point?
Re: How to see coordinates of and/or move a Point?
Using Part workbench you create primitives or extrude a sketch, then move the solid to the desired location, with the transform tool, the Edit>Placement menu, or adjust the placement properties in the Properties view.
If you hover over an edge or vertex the coordinates are displayed in the status bar.- Question 1: How do I display the coordinates of that single point (or a point on a shape) in either 2d or 3d space?
Transform tool is used to move solids objects in 3D space.- Question 2: How do I relocate the point to a specific location on the x,y plane? Or in 3D space?
Vertices are moved by changing the sketch (which is a 2D plane) or in the case of a point object, the Draft workbench tools that allow snapping (this assumes you are not using a sketch to define your solid and are create 3D geometry (not solids) in Draft workbench.
- Shalmeneser
Which ones ?
Thanks for the replay and the tips & info.
In the process I discovered an alternate solution that works in Part Design/Sketcher...
Part Design/Sketcher Tip:
Question 1: How to display the coordinates of a point?
Answer: Click the point then click on the "Lock" icon...
and the coordinates will appear.
Question 2: How to relocate the point to a specific location?
Answer: Click on the Lock Constraints and change them to the new position.
Optionally: After moving it you can delete the "Lock" constraints and your sketch will remain in the new position.
Everybody probably already knew this... but now, I know it too
