Help with front of car chassis
I am a total noob to freecad. i am working on a project to design my own car. i am leaning how to use cad on a lotus 7 chassis to figure how to use free cad. I am running into a problem at the front of the car. the to tube is set back 3 inchs from the bottom tube. I having trouble with the side tubes angles. i have supplied pics. thanks in advanced.
- 20211008_173816.jpg (119.85 KiB) Viewed 1348 times
- 20211014_162856.jpg (64.53 KiB) Viewed 1348 times
- 20211014_160735.jpg (61.39 KiB) Viewed 1348 times
- 20211014_160732.jpg (74.47 KiB) Viewed 1348 times
- 20211014_160729.jpg (26.35 KiB) Viewed 1348 times
Re: Help with front of car chassis
Hi and welcome to the forum!
How can we help? There is no file nor detailed description which both would be helpful for the helpers.
It's hard to know what to say. I guess you need to sketch from the side so you can create the angle required.
Welcome, I really think you're trying to run before you can walk (especially IMHO using Part Design Wb). I've attached what I believe you require and I've tried to put some hints in the names of the objects but I had to use some offsetting that wouldn't be obvious to a noob along with expressions (suchas <<FrontTopTube_BoxXSection>>.Constraints.BoxSectionOS) so you can change the wall thickness in one sketch an it propagates to all the others.tmachek60 wrote: ↑Tue Oct 19, 2021 1:05 am I am a total noob to freecad. i am working on a project to design my own car. i am leaning how to use cad on a lotus 7 chassis to figure how to use free cad. I am running into a problem at the front of the car. the to tube is set back 3 inchs from the bottom tube. I having trouble with the side tubes angles. i have supplied pics. thanks in advanced.
Modelled using:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- Lotus7FrontChassisMember.FCStd
- (41.77 KiB) Downloaded 33 times
- Shalmeneser
There is a key on your keyboard to take picture of the screen : PrnScr (print screen) or something else.
The quality will be better than with a camera.
And the book must be 'parallel' to the camera.
THANK YOU SO MUCH SYRES. YOU ARE MY HERO. I cant thank you enough. i was struggling for a week on this problem. I learned so much.
- 20211019_195210.jpg (247.53 KiB) Viewed 1024 times
Syres wrote: ↑Tue Oct 19, 2021 7:14 amWelcome, I really think you're trying to run before you can walk (especially IMHO using Part Design Wb). I've attached what I believe you require and I've tried to put some hints in the names of the objects but I had to use some offsetting that wouldn't be obvious to a noob along with expressions (suchas <<FrontTopTube_BoxXSection>>.Constraints.BoxSectionOS) so you can change the wall thickness in one sketch an it propagates to all the others.tmachek60 wrote: ↑Tue Oct 19, 2021 1:05 am I am a total noob to freecad. i am working on a project to design my own car. i am leaning how to use cad on a lotus 7 chassis to figure how to use free cad. I am running into a problem at the front of the car. the to tube is set back 3 inchs from the bottom tube. I having trouble with the side tubes angles. i have supplied pics. thanks in advanced.
Modelled using:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thank you so much for making the model and allowing me the learn freecad. You are truly a human for taking the time to show me how to do this.
