A2plus constraint - which part has dominance?
keltel
Post by keltel »
Hello.
In this example I have a base plate with a 25mm dia hole, and a bearing block on top. I select the hole edge and the bearing inner edge and apply a constraint - either axis-axis or point-point. Each time the base plate moves (with respect to it's sketch) and the bearing stays put. If I set the bearing to fixed position = false then the constraint fails with "The highlighted parts were not moved. they are not constrained to a fixed part!"
How can I make the bearing move instead?
TIA. Kel.
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Re: A2plus constraint - which part has dominance?
Post by babaroga »
Make base plate fixed...
Moved to Assembly forum.
