OK, so the "default" view is the split-apart view, with the other, "real" view being available.
I switched the units to Imperial Decimal, and that did seem to work for some dimensions - I discovered if you want to change dimensions, you have to put "in" after the number... "0.025" will not work to affect a change, but "0.025 in" will.
Now, however, I have tried to run the G-code for this on my unit (using a stubby broken bit in my motor), and find that it moves to position, goes down INTO the wood and attempts to move in the circular pattern, WITHOUT the motor running. So, have to abort the running... Looking at the G-code that FC creates, I see that Z numbers are TOTALLY wrong... I have it set to step down by 0.025, starting at 0.00 (see Profile pic). The G-code is totally messed up, as it starts the first step @ -0.635, 2nd step down is -1.270, 3rd is -1.915, 4th (last) is -2.540 - see the Overall view for this.
My piece is 0.10" thick!!
Viewing the model view of the piece shows it looks fine:
- Model-body Job Edit.png (99.13 KiB) Viewed 1583 times
Looking at the overall view, however, shows a problem:
- Overall view.png (130.6 KiB) Viewed 1583 times
Profile settings:
- Profile.png (79.55 KiB) Viewed 1583 times
The program is also funky... note that the word "Job" is missing from the tree now... and, if I click on "Stock 001", the program crashes.
I deleted the Job, created a new one, Same results. Sigh.
(Exported by FreeCAD)
(Post Processor: grbl_post)
(Output Time:2021-10-21 11:17:22.037695)
(Begin preamble)
G17 G90
G21
(Begin operation: Fixture)
(Path: Fixture)
G54
(Finish operation: Fixture)
(Begin operation: TC: Default Tool)
(Path: TC: Default Tool)
(TC: Default Tool)
(Begin toolchange)
( M6 T1.0 )
M3 S1000.0
(Finish operation: TC: Default Tool)
(Begin operation: Profile)
(Path: Profile)
(Profile)
(Compensated Tool Path. Diameter: 5.0)
G0 Z5.000
G0 X0.000 Y0.000
G0 X10.961 Y11.222
G0 X10.961 Y11.222 Z3.000
G1 X10.961 Y11.222 Z-0.635 F127.000
G2 X17.983 Y33.960 Z-0.635 I9.344 J9.567 K0.000 F254.000
G2 X33.475 Y23.112 Z-0.635 I2.322 J-13.170 K0.000 F254.000
G2 X22.627 Y7.619 Z-0.635 I-13.170 J-2.322 K0.000 F254.000
G2 X10.961 Y11.222 Z-0.635 I-2.322 J13.170 K0.000 F254.000
G1 X10.961 Y11.222 Z-1.270 F127.000
G2 X17.983 Y33.960 Z-1.270 I9.344 J9.567 K0.000 F254.000
G2 X33.475 Y23.112 Z-1.270 I2.322 J-13.170 K0.000 F254.000
G2 X22.627 Y7.619 Z-1.270 I-13.170 J-2.322 K0.000 F254.000
G2 X10.961 Y11.222 Z-1.270 I-2.322 J13.170 K0.000 F254.000
G1 X10.961 Y11.222 Z-1.905 F127.000
G2 X17.983 Y33.960 Z-1.905 I9.344 J9.567 K0.000 F254.000
G2 X33.475 Y23.112 Z-1.905 I2.322 J-13.170 K0.000 F254.000
G2 X22.627 Y7.619 Z-1.905 I-13.170 J-2.322 K0.000 F254.000
G2 X10.961 Y11.222 Z-1.905 I-2.322 J13.170 K0.000 F254.000
G1 X10.961 Y11.222 Z-2.540 F127.000
G2 X17.983 Y33.960 Z-2.540 I9.344 J9.567 K0.000 F254.000
G2 X33.475 Y23.112 Z-2.540 I2.322 J-13.170 K0.000 F254.000
G2 X22.627 Y7.619 Z-2.540 I-13.170 J-2.322 K0.000 F254.000
G2 X10.961 Y11.222 Z-2.540 I-2.322 J13.170 K0.000 F254.000
G0 Z5.000
G0 Z5.000
(Finish operation: Profile)
(Begin postamble)
M5
G17 G90
M2
