Basic "easy" stuff? (Solved)
dkolars
Post by dkolars »
Long time computer user here (Commodore 64 and on), retired IT (Win NT4.0), did a lot of work with spreadsheets, databases, HTML, word processing, etc. etc.
I'm a woodworker/luthier, lathe, laser engraving, etc... Use Inkscape a lot, but was not having the best of luck with its G-code generator, so, got FreeCAD to see what it could do. I got a Genmitsu 3018 Pro about 3-4 weeks ago, and am totally adlepated right about now.
Here's my info from the help file:
OS: Ubuntu 20.04.3 LTS (XFCE/xubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
I'm using a HP Pavilion laptop with Win 10 to run the machine, transferring data on USB stick between systems.
I thought my project would be super simple, but...
My end goal is to make a wooden disc, 2-3" in diameter, 0.1 - 0.2" thick. In this disk, I'd like to have 5 holes, 5/16th down to 1/16th by 16ths, no particular order for the holes.
I've given up on that for now and am trying to simply make a hole in a shape! Have watched HOURS of YouTube vids, my buddy has been running RhinoCAD for about 20 yrs and has helped with some of the basics, but I am stymied.
1) Part Design: Create & make active body on X-Y plane, create sketch
2) Sketcher: create 1.5" square
3) Sketcher: create 1" circle inside that square
4) Part Design: Pad to 0.1"
... I now have a square with a hole in it.
5) Path: Create Job
6) Set box, dimensions, bit, set Origin to lower left corner, processor to "grbl"
7) Select inside face of hole, and now the fun starts...
What I envision is my cutter bit, going around the inside edge of the hole and creating a hole AND a disc.
IF I use "Creates a Path 3D pocket object" the program wants to remove all the material to create the hole.
IF I use "Profile entire model...", the program seems to do what I want, but...
Looking at the Profile sheet, I cannot change the "Stepdown" from 0.9483 thou... Reading a dozen or so pages on this on the web is no help at all...
Since I'm only cutting 0.1", that seems wrong. I'd like to step it by 0.05 or 0.025 and cut the disc out in 2-4 passes...
But, if I go ahead and use those settings, set the Operation to Use Start Point & Process Perimeter, the graphic depiction of the results seems to be OK.... however, it takes a gazillion passes around to accomplish it, and looking at the G-code, the bit is going from the top surface down to -2.539999, which seems a bit extreme for a 0.1 thick piece.
And, the G-code has I, J, & K values, and I have to edit file to delete all the K0.000 instances, as it will not run with them.
THEN, when I attempt to run the file, using Candle, the bit moves to the proper location, drops down to touch the surface, raises back up, and the program says it was "Completed, run time 6 sec".
Should not the G-code have simply the R code instead of I, J, K?
Here's the G-code:
Profile)
(Uncompensated Tool Path)
G0 Z5.000000
G0 X0.000000 Y0.000000
G0 X8.763650 Y8.791472
G0 X8.763650 Y8.791472 Z3.000000
G1 X8.763650 Y8.791472 Z-0.025000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.025000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.025000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.025000
G1 X8.763650 Y8.791472 Z-0.050000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.050000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.050000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.050000
G1 X8.763650 Y8.791472 Z-0.075000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.075000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.075000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.075000
G1 X8.763650 Y8.791472 Z-0.100000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.100000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.100000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.100000
G1 X8.763650 Y8.791472 Z-0.125000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.125000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.125000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.125000
G1 X8.763650 Y8.791472 Z-0.150000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.150000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.150000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.150000
G1 X8.763650 Y8.791472 Z-0.175000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.175000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.175000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.175000
G1 X8.763650 Y8.791472 Z-0.200000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.200000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.200000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.200000
G1 X8.763650 Y8.791472 Z-0.225000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.225000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.225000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.225000
G1 X8.763650 Y8.791472 Z-0.250000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.250000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.250000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.250000
G1 X8.763650 Y8.791472 Z-0.275000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.275000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.275000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.275000
G1 X8.763650 Y8.791472 Z-0.300000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.300000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.300000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.300000
G1 X8.763650 Y8.791472 Z-0.325000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.325000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.325000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.325000
G1 X8.763650 Y8.791472 Z-0.350000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.350000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.350000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.350000
G1 X8.763650 Y8.791472 Z-0.375000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.375000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.375000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.375000
G1 X8.763650 Y8.791472 Z-0.400000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.400000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.400000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.400000
G1 X8.763650 Y8.791472 Z-0.425000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.425000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.425000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.425000
G1 X8.763650 Y8.791472 Z-0.450000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.450000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.450000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.450000
G1 X8.763650 Y8.791472 Z-0.475000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.475000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.475000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.475000
G1 X8.763650 Y8.791472 Z-0.500000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.500000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.500000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.500000
G1 X8.763650 Y8.791472 Z-0.525000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.525000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.525000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.525000
G1 X8.763650 Y8.791472 Z-0.550000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.550000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.550000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.550000
G1 X8.763650 Y8.791472 Z-0.575000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.575000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.575000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.575000
G1 X8.763650 Y8.791472 Z-0.600000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.600000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.600000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.600000
G1 X8.763650 Y8.791472 Z-0.625000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.625000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.625000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.625000
G1 X8.763650 Y8.791472 Z-0.650000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.650000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.650000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.650000
G1 X8.763650 Y8.791472 Z-0.675000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.675000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.675000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.675000
G1 X8.763650 Y8.791472 Z-0.700000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.700000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.700000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.700000
G1 X8.763650 Y8.791472 Z-0.725000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.725000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.725000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.725000
G1 X8.763650 Y8.791472 Z-0.750000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.750000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.750000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.750000
G1 X8.763650 Y8.791472 Z-0.775000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.775000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.775000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.775000
G1 X8.763650 Y8.791472 Z-0.800000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.800000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.800000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.800000
G1 X8.763650 Y8.791472 Z-0.825000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.825000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.825000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.825000
G1 X8.763650 Y8.791472 Z-0.850000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.850000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.850000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.850000
G1 X8.763650 Y8.791472 Z-0.875000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.875000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.875000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.875000
G1 X8.763650 Y8.791472 Z-0.900000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.900000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.900000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.900000
G1 X8.763650 Y8.791472 Z-0.925000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.925000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.925000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.925000
G1 X8.763650 Y8.791472 Z-0.950000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.950000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.950000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.950000
G1 X8.763650 Y8.791472 Z-0.975000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-0.975000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-0.975000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-0.975000
G1 X8.763650 Y8.791472 Z-1.000000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.000000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.000000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.000000
G1 X8.763650 Y8.791472 Z-1.025000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.025000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.025000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.025000
G1 X8.763650 Y8.791472 Z-1.050000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.050000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.050000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.050000
G1 X8.763650 Y8.791472 Z-1.075000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.075000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.075000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.075000
G1 X8.763650 Y8.791472 Z-1.100000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.100000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.100000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.100000
G1 X8.763650 Y8.791472 Z-1.125000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.125000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.125000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.125000
G1 X8.763650 Y8.791472 Z-1.150000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.150000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.150000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.150000
G1 X8.763650 Y8.791472 Z-1.175000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.175000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.175000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.175000
G1 X8.763650 Y8.791472 Z-1.200000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.200000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.200000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.200000
G1 X8.763650 Y8.791472 Z-1.225000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.225000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.225000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.225000
G1 X8.763650 Y8.791472 Z-1.250000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.250000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.250000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.250000
G1 X8.763650 Y8.791472 Z-1.275000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.275000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.275000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.275000
G1 X8.763650 Y8.791472 Z-1.300000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.300000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.300000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.300000
G1 X8.763650 Y8.791472 Z-1.325000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.325000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.325000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.325000
G1 X8.763650 Y8.791472 Z-1.350000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.350000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.350000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.350000
G1 X8.763650 Y8.791472 Z-1.375000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.375000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.375000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.375000
G1 X8.763650 Y8.791472 Z-1.400000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.400000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.400000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.400000
G1 X8.763650 Y8.791472 Z-1.425000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.425000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.425000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.425000
G1 X8.763650 Y8.791472 Z-1.450000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.450000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.450000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.450000
G1 X8.763650 Y8.791472 Z-1.475000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.475000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.475000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.475000
G1 X8.763650 Y8.791472 Z-1.500000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.500000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.500000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.500000
G1 X8.763650 Y8.791472 Z-1.525000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.525000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.525000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.525000
G1 X8.763650 Y8.791472 Z-1.550000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.550000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.550000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.550000
G1 X8.763650 Y8.791472 Z-1.575000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.575000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.575000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.575000
G1 X8.763650 Y8.791472 Z-1.600000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.600000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.600000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.600000
G1 X8.763650 Y8.791472 Z-1.625000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.625000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.625000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.625000
G1 X8.763650 Y8.791472 Z-1.650000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.650000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.650000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.650000
G1 X8.763650 Y8.791472 Z-1.675000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.675000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.675000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.675000
G1 X8.763650 Y8.791472 Z-1.700000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.700000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.700000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.700000
G1 X8.763650 Y8.791472 Z-1.725000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.725000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.725000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.725000
G1 X8.763650 Y8.791472 Z-1.750000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.750000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.750000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.750000
G1 X8.763650 Y8.791472 Z-1.775000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.775000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.775000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.775000
G1 X8.763650 Y8.791472 Z-1.800000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.800000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.800000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.800000
G1 X8.763650 Y8.791472 Z-1.825000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.825000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.825000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.825000
G1 X8.763650 Y8.791472 Z-1.850000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.850000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.850000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.850000
G1 X8.763650 Y8.791472 Z-1.875000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.875000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.875000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.875000
G1 X8.763650 Y8.791472 Z-1.900000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.900000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.900000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.900000
G1 X8.763650 Y8.791472 Z-1.925000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.925000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.925000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.925000
G1 X8.763650 Y8.791472 Z-1.950000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.950000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.950000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.950000
G1 X8.763650 Y8.791472 Z-1.975000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-1.975000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-1.975000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-1.975000
G1 X8.763650 Y8.791472 Z-2.000000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.000000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.000000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.000000
G1 X8.763650 Y8.791472 Z-2.025000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.025000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.025000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.025000
G1 X8.763650 Y8.791472 Z-2.050000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.050000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.050000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.050000
G1 X8.763650 Y8.791472 Z-2.075000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.075000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.075000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.075000
G1 X8.763650 Y8.791472 Z-2.100000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.100000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.100000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.100000
G1 X8.763650 Y8.791472 Z-2.125000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.125000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.125000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.125000
G1 X8.763650 Y8.791472 Z-2.150000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.150000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.150000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.150000
G1 X8.763650 Y8.791472 Z-2.175000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.175000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.175000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.175000
G1 X8.763650 Y8.791472 Z-2.200000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.200000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.200000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.200000
G1 X8.763650 Y8.791472 Z-2.225000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.225000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.225000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.225000
G1 X8.763650 Y8.791472 Z-2.250000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.250000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.250000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.250000
G1 X8.763650 Y8.791472 Z-2.275000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.275000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.275000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.275000
G1 X8.763650 Y8.791472 Z-2.300000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.300000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.300000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.300000
G1 X8.763650 Y8.791472 Z-2.325000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.325000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.325000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.325000
G1 X8.763650 Y8.791472 Z-2.350000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.350000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.350000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.350000
G1 X8.763650 Y8.791472 Z-2.375000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.375000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.375000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.375000
G1 X8.763650 Y8.791472 Z-2.400000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.400000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.400000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.400000
G1 X8.763650 Y8.791472 Z-2.425000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.425000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.425000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.425000
G1 X8.763650 Y8.791472 Z-2.450000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.450000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.450000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.450000
G1 X8.763650 Y8.791472 Z-2.475000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.475000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.475000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.475000
G1 X8.763650 Y8.791472 Z-2.500000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.500000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.500000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.500000
G1 X8.763650 Y8.791472 Z-2.525000
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.525000
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.525000
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.525000
G1 X8.763650 Y8.791472 Z-2.539999
G2 I10.272544 J10.305156 K0.000000 X4.494389 Y19.603902 Z-2.539999
G2 I14.541805 J-0.507274 K0.000000 X33.577999 Y18.589354 Z-2.539999
G2 I-14.541805 J0.507274 K0.000000 X8.763650 Y8.791472 Z-2.539999
G0 F0.000000 Z5.000000
G0 Z5.000000
This makes learning relational databases when they first came out seem easy!!
What am I doing wrong??? TIA DK
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
Re: Basic "easy" stuff?
Hi and welcome to the forum!
You can change the stepdown if you click on the f(x) symbol at the right. Although it doesn't show the change immediately, it will change. You can see it on the next reopen.
Some organizational remarks:
I will move this post to the Path workbench subforum.
You should use the current 0.20 version from https://github.com/FreeCAD/FreeCAD-AppI ... kly-builds . There have been important improvements made to Path workbench.
Please edit your post above and place the G-code in code tags instead of quote.
dkolars
Post by dkolars »
Well, went to the git-hub, d/l ./FreeCAD_weekly-builds-26155-Linux-Conda_glibc2.12-x86_64.AppImage... read the instructions, ran
bash: ./FreeCAD_weekly-builds-26155-Linux-Conda_glibc2.12-x86_64.AppImage: Permission denied
So, ran
sudo: ./FreeCAD_weekly-builds-26155-Linux-Conda_glibc2.12-x86_64.AppImage: command not found
No clue... Went to website, and it's got 19.something and link to builds...
And f(x) is what that blue circle is supposed to be? Totally illegible... Pale blue circle w/white in it. I can click that a thousand times and it will NOT change from "0.9843 thou"... The other settings with that blue circle will change after 3 tries, every time, 3 tries: 1) Clear, OK. 2) enter new value, OK. 3) open again, and click OK, THEN it takes!
I changed to code from quote, thanks for keeping me up to date!
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
Shalmeneser
Post by Shalmeneser »
dkolars wrote: Wed Oct 20, 2021 7:55 pm ...
Download appimage.
Left-clicks on the appimage and gives permissions.
Then run it.
no more work.
dkolars
Post by dkolars »
Shalmeneser wrote: Wed Oct 20, 2021 8:02 pm
Download appimage.
Then run it.
no more work.
OK, got it... for me is right-click, make executable, then it runs. Thank you! Don't work with AppImage very often...
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
dkolars
Post by dkolars »
Down the rabbit hole we go: d/l appimagetool-x86_64.AppImage so I could extract the squash-fs as per instructions... then get:
dk@dk-desktop:~/Downloads$ sudo ./appimagetool-x86_64.AppImage squashfs-root
appimagetool, continuous build (commit 8bbf694), build <local dev build> built on 2020-12-31 11:48:33 UTC
Using architecture x86_64
/home/dk/Downloads/squashfs-root should be packaged as appimagetool-x86_64.AppImage
AppStream upstream metadata found in usr/share/metainfo/appimagetool.appdata.xml
Trying to validate AppStream information with the appstreamcli tool
In case of issues, please refer to https://github.com/ximion/appstream
org.freecadweb.FreeCAD.appdata.xml
W: appimagetool.desktop:3: cid-desktopapp-is-not-rdns appimagetool.desktop
Validation failed: warnings: 1, pedantic: 4
run_external: subprocess exited with status 3Failed to validate AppStream information with appstreamcli
The " https://github.com/ximion/appstream org.freecadweb.FreeCAD.appdata.xml" is not a valid addy.
Think it's time for some garden cleanup to relax.
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
user1234
Post by user1234 »
Never ever open a program as root!
I use very seldom Appimages. But when, then i active them like the description in https://appimage.org/. While Subsurface*is the replacement of the name of the program.
Greetings
user1234
GeneFC
Post by GeneFC »
dkolars wrote: Wed Oct 20, 2021 12:08 am What am I doing wrong?
If you can post your FCStd file it is likely that someone can figure out the issues with your model or the path creation process quite quickly.
I looked at the g-code. It works, as you say, but the stepdown is tiny. However, there is no way to know what is happening in the FC file to cause this g-code issue.
Gene
dkolars
Post by dkolars »
GeneFC wrote: Wed Oct 20, 2021 9:57 pm
Gene
OK, here 'tis. TY.
Test hole.FCStd
(25.58 KiB) Downloaded 31 times
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
dkolars
Post by dkolars »
user1234 wrote: Wed Oct 20, 2021 9:13 pm Never ever open a program as root!
Greetings
user1234
dk@dk-desktop:~/Downloads$ chmod a+x appimagetool-x86_64.AppImage
dk@dk-desktop:~/Downloads$ appimagetool-x86_64.AppImage
appimagetool-x86_64.AppImage: command not found
Nope
64-bit
Qt version: 5.12.9
OCC version: 7.4.0
