Fillets in a Corner of two Pads
dasarne
Post by dasarne »
Hello all,
I would like to put a fillet between two pads.
Can you advise me a good documentation or post here how to do it?
When I do this in the Part Design Workbench I get the following error message:
When in the Part Workbench it doesn't work either:
Here is the file:
Fillet-Test.FCStd
(17.48 KiB) Downloaded 26 times
Freecad-Version:
OS: Windows 10 Version 2009
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
and
FreeCad 0.19 on Archlinux
Yours
Arne
papyblaise
Re: Fillets in a Corner of two Pads
Post by papyblaise »
just do "Refine = True"
dasarne
Post by dasarne »
Sorry papyblaise, but ... where can I set Refine = True?
I said so flippantly earlier that Freecat 19 on Ubuntu has the same problem. But that is not true.
So this might be a bug in FC 20 (under Windows?).
Thanks.
Yours
Arne
papyblaise
ici
refine = true.PNG (32.06 KiB) Viewed 1501 times
Shalmeneser
Post by Shalmeneser »
Your file in the same version do the fillet (selecting Edge12).
I don't understand.
Refine doesn't change anything (but could help in other situation).
OS: Linux Mint 20.2 (MATE/mate)
Version: 0.20.26155 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: French/France (fr_FR)
Fillet-Test_SHALM.FCStd
(21.76 KiB) Downloaded 18 times
drmacro
Post by drmacro »
Just to be specific.
You have a Part Design Body. A Body represents a single solitary solid. That solid is the accumulation of all operations performed in the Body. Each operation (Pad, Pocket, Revolve, etc.) creates a feature under the Body.
The last feature is referred to as the Tip. The is the accumulated solid. This is also one reason the previous features are hidden.
When you perform a fillet operation on an edge or face it is on the solid, not between the Pads that created it.
I know this sounds pedantic, and may not seem relevant, but, it is important to understand that the features of a Body are not stand alone solids.
So you aren't doing a Fillet between the Pad features.
dasarne
Post by dasarne »
If my Windows version of FC 20 is now the only one that cannot create the fillet in the file, the problem is not relevant right? :)
GeneFC
Post by GeneFC »
Sketch001 is slightly out of position. If the lower left corner of Sketch001 is set to be coincident with the origin the fillet will work. (Since it is already very close I presume that was the intention.)
This problem can be seen if refine is set to true. The shape shows a seam on one side instead of an invisible join.
Filleting and chamfering often have problems when there are small offsets like that.
Fully constraining your sketches would probably avoid the problem. :?
Gene
Shalmeneser
Sketches are not constrained :oops: :x .
Sketch001 is not coincident with the origin !
But the Fillet should work nevertheless.
Capture du 2021-10-20 20-47-09.png (9.11 KiB) Viewed 1382 times
Capture du 2021-10-20 20-47-32.png (7.75 KiB) Viewed 1382 times
heda
Post by heda »
or just sketch the cross-section...
Snip macro screenshot-80f178.png (20.17 KiB) Viewed 1303 times
Unnamed.FCStd
(13.31 KiB) Downloaded 16 times
