Hi, I am sharing a bug I am seeing, here.
There is a pad feature (the last one), after a polar pattern that has the refine true. This feature should be a pad, but it is being created as a pocket. To be able to share, I removed some of the objects/features of this file tho.
I was able to fix this by removing the polar pattern and recreating it. Then maybe because it was not created with the Refine = True, it started to work fine.
OS: Ubuntu 21.10 (GNOME/gnome)
Version: 0.20.
Branch: unknown
Hash: 8fceac17628778bd0b2ba4c60bafd6494348ac08
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
Pad creating a Pocket
Re: Pad creating a Pocket
If you turn off the transparency you see that all the faces turn black, indicating inverted normals. I have no idea what's causing that. Obviously, the refine has something to do with it somehow.
I don't see any faces turning black here, but I can confirm the pad turing into a pocket.
OS: macOS 10.16
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
This happens if I delete the final pad and do it again.
OS: Windows 10 (10.0)
Version: 0.20.25997 (Git)
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
Qt version: 5.12.9
OCC version: 7.5.2
This is how it looks here, when I do
- load file
- remove pad
- add pad
- set transparency to 0
the same with other sequence:
- load file
- remove pad
- add pad
It could be the slightly different OCC versions. Correct seems none of these.
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- load file
- remove pad
- add pad
- load file
- remove pad
- add pad
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- SnipScreenshot-d9ff3f.png (44.03 KiB) Viewed 942 times
I can confirm it for OCC 7.3 and 7.6 that the shape gets inverted when the Refine option is set. It's also possible to independently test it from this project. Therefore make sure Refine is set to false, make a simple copy of the last pad feature and now apply the Refine shape command from the Part wb.
If you have set a certain back face color in the settings then it may be not black. And you have to set the Lighting of the shape to One side rendering
When looking at the non-refined pad then many faces have orientation forward and many others are reversed. The refinement algorithm seems to ignore the orientation of the joined faces and creates a resulting face with orientation forward. Because the first face of the refined model has wrong orientation the whole solid will be wrong, too.
Here is the extracted bottom part of this model
- reversed_faces.brp
- (84.26 KiB) Downloaded 20 times
Fixed with git commit aa19f8b05f
