Mesh: Fill a hole/add a triangle
amarilisppt
Post by amarilisppt »
I tried to use the Mesh/Fill a hole and Add a triangle to add a triangle to an opened mesh side. It did not run and, already, I do not see any color change of vertex, etc... as described in FC help. I switched int Edition mode, but no improvment.
Please note that I use W10, FC0.19 (same with 0.18) and a touchpad.
Did someone have the same concern (did not see that point in hte forum search neither on tutorials, but...)? Solved?
Thanks.
TheMarkster
Re: Mesh: Fill a hole/add a triangle
Post by TheMarkster »
I've used it before and it worked for me. Can't remember if used close hole or fill holes. It was a mesh I had cut with a plane and where it had been cut was left open. You might want to update to the latest 0.20 developer build. I know some very recent work has been done on that workbench.
