[Solved] Need help recreating a simple shape
pathfinder
Re: Need help recreating a simple shape
Post by pathfinder »
thomas-neemann wrote: Fri Oct 22, 2021 1:55 pm
here is a possibility
Thanks for your answer.
What I probably forgot to mention is that I already have the shape as a mesh and want to rebuild as a solid; I could just transform what I have to a solid (I know the way you've shown). The issue here is that the many polygons make working with it a real pain and can throw off the Path tools (although they've gotten far better at dealing with this kind of stuff even in the last few weeks).
That's why I want to rebuild this shape as a solid in the first place; so I can work with it as a solid.
drmacro
Post by drmacro »
I noted that the geometry in the file @thomas-neeman posted didn't pass geometry check (in master 0.20, was it created in linkstage3???)
Just for another take on this (couldn't pass up the challenge :mrgreen: )...somewhat low level, less steps, but, the result is valid solid:
Snip macro screenshot-e3e2f4.png (94.1 KiB) Viewed 1219 times
SweepShapeExample-4.FCStd
(236.27 KiB) Downloaded 24 times
Shalmeneser
Post by Shalmeneser »
Pipe with Frenet Fixed at the corners (and some tricks but TNP).
 └ Body (Body)
    ├ Pad (Pad)
    │  └ Sketch (Sketch)
    ├ AdditivePipe (AdditivePipe)
    │  ├ Sketch001 (Sketch)
    │  └ Sketch (Sketch)
    ├ Pocket (Pocket)
    │  └ Sketch002 (Sketch)
    ├ PolarPattern (PolarPattern)
    ├ AdditivePipe001 (AdditivePipe)
    │  ├ Sketch004 (Sketch)
    │  └ Sketch003 (Sketch)
    ├ PolarPattern001 (PolarPattern)
    └ Pocket001 (Pocket)
       └ Sketch (Sketch)
SweepShapeExample_SHALM.FCStd
(127.3 KiB) Downloaded 23 times
Capture du 2021-10-22 18-10-51.png (29 KiB) Viewed 1200 times
Shalmeneser
drmacro wrote: Fri Oct 22, 2021 3:46 pm ...
Problem with the center line (not rounded).
Capture du 2021-10-22 18-48-03.png (4.45 KiB) Viewed 1172 times
Shalmeneser
(Less TNP ?)
Problem to unpad (=pocket) the 1s sketch. Don't understand why.
SweepShapeExample_SHALM2.FCStd
(130.69 KiB) Downloaded 18 times
pathfinder
Shalmeneser wrote: Fri Oct 22, 2021 4:13 pm Pipe with Frenet at the corners (and some tricks but TNP).
 └ Body (Body)
    ├ Pad (Pad)
    │  └ Sketch (Sketch)
    │  └ Sketch (Sketch)
    ├ Pocket (Pocket)
       └ Sketch (Sketch)
This looks really good, but I have a hard time following your steps based on the file. What I got:
- you made the shape by creating a pipe
- you cut out the corners
- you replaced the corners with a shape that's the chamfer?
Sorry for being dense, it's just a lot going on that is new to me.
Also, what's TNP?
Shalmeneser
pathfinder wrote: Fri Oct 22, 2021 5:30 pm
TNP = Topological_naming_problem
* 1st pipe for the global body
* pocket to cut one corner
* small pipe to complete this pocket (mode Fixed = the form doesn't turn, just sliding)
* Repetition×6 (PolarPattern)
The 1st pad is to keep one body during all the construction (corner cuts create 6 bodies without this precaution). It'll be suppressed at the end.
BTW, asking (politely) is key to undertanding.
thomas-neemann
Post by thomas-neemann »
pathfinder wrote: Fri Oct 22, 2021 2:05 pm ...That's why I want to rebuild this shape as a solid in the first place; so I can work with it as a solid.
here is a quick possibility
https://www.youtube.com/watch?v=dcyNubY3BgM
phpBB [video]
pathfinder
thomas-neemann wrote: Fri Oct 22, 2021 5:50 pm
Oh yes, that's a neat trick, thanks!
Shalmeneser wrote: Fri Oct 22, 2021 5:46 pm
I'll need some time to process this, but I'm sure I can work with that, thanks!
And thanks for your explanation of TNP, I'm using RealThunders branch, which I think fixed it to some degree.
I'll mark this as solved, I' think I can figure it out from here.
Shalmeneser
pathfinder wrote: Fri Oct 22, 2021 6:07 pm And thanks for your explanation of TNP, I'm using RealThunders branch, which I think fixed it to some degree.
I believe.
