If you insist...
[Solved] Need help recreating a simple shape
Re: Need help recreating a simple shape
- SweepShapeExample-5.FCStd
- (216.18 KiB) Downloaded 19 times
Yes, mitigated...not gone unfortunately.pathfinder wrote: ↑Fri Oct 22, 2021 6:07 pm ...
And thanks for your explanation of TNP, I'm using RealThunders branch, which I think fixed it to some degree.
Re: [Solved] Need help recreating a simple shape
Here is a model following your original approach. My guess is, that you forgot to set Fuse=True.
- hexaRound.FCStd
- (32.87 KiB) Downloaded 21 times
- Snip macro screenshot-d5002d.png (4.94 KiB) Viewed 656 times
- pathfinder
Thanks for your input, this is indeed very close to what I wanted. I didn't figure out the array tool at the time, so I copied and rotated the parts and tried to use boolean to fuse them.
