https://we.tl/t-sYp1EaO16t
I was not able to upload the file but there is a link above. No need for an account.
Is there a reason why the polygon sweeps perfectly but the circle simply won't do it?
Please help!
polygon works but circle won't sweep correctly
- sweep exercise 010.PNG (54.31 KiB) Viewed 1127 times
Re: polygon works but circle won't sweep correctly
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/South Africa (en_ZA)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- papyblaise
you must use PartWb for Sweeps
you have to draw the sketches in a place where they are as well as possible perpendicular to the path
use the edge of the volume (like sole) as a path and leave Frenet = false
- semelle.FCStd
- (806 KiB) Downloaded 24 times
- semelle.PNG (27.61 KiB) Viewed 1066 times
even when I use your sketch to sweep the edge I get a messed up result.papyblaise wrote: ↑Sat Oct 23, 2021 2:34 pm you must use PartWb for Sweeps
What am I doing wrong? I used PartWB.
- sweep exercise 011.PNG (76.58 KiB) Viewed 1031 times
- papyblaise
you have to update your version Fc
Both faces are working. But adjust your deviation parameter lower (under 0,5) to get a nice result.
Check the curve continuity as well, your curve is not here (with Comb from curves wb)
- sweep045_2.FCStd
- (1011.91 KiB) Downloaded 22 times
- Capture.JPG (88.73 KiB) Viewed 960 times
deviation parameter was the problem. I set it to 0.45 and now I can see the full sweep!!! Thank you.
