Inverted pocket
geek emeritus
Inverted pocket
Post by geek emeritus »
I am trying beginner stuff. I managed to get a pocket in a box, but I draw the rectangle for the pocket on top, and when I hit OK, no pocket shows up on top. Flip it over and there's the pocket, on the bottom. How is this possible?
INVERTED POCKET.FCStd
(31.36 KiB) Downloaded 24 times
GeneFC
Re: Inverted pocket
Post by GeneFC »
The sketch is on the "bottom", specifically the x-y plane. There is only one way the pocket can form from there.
I do not know what you tried to do, but the sketch is not on the "top".
Gene
Re: Inverted pocket
What you uploaded has no inverted sketch and the pocket is not reverted either. Yet the pocket works.
If you have a bit more experience, you should refrain from attaching sketches to faces, see this page, especially the paragraph about creating stable models.
