When I create an LCS concentric to the larger radius of the top left teardrop-shaped hole in this Part the z_axis is aligned correctly but the others are rotated 122 degrees.
The FCStd can be downloaded at https://1drv.ms/u/s!ArMxdUYEh9fKwAcGMKn ... 1?e=7CArsk. It is marginally too large.
Apart from guessing, which is what I am doing at the moment, is there a kosher way to get the X-axis of the LCS horizontal?LCS on Arc misaligned
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
- papyblaise
Re: LCS on Arc misaligned
Abracadabra also worksApart from guessing
without knowing which other direction, LCS guess you only have the Z axis
there is several question: why does your file start at sketch012, where are the previous 11
there is a problem in "BottomPlate Foot Fillet
and 1 other manifesto but I don't know where
a Refine = true from time to time is not too much
- erreurs.PNG (114.17 KiB) Viewed 921 times
You want spells? Try https://www.amazon.com/Wizard-Id-Frammi ... 0449136817
Zoom out to make the object smaller - you'll see the other axes.papyblaise wrote: ↑Sun Oct 24, 2021 3:06 pm without knowing which other direction, LCS guess you only have the Z axis
There are 30+ Bodies in the Document and 300-odd sketches. What I sent was trimmed to the body in question.papyblaise wrote: ↑Sun Oct 24, 2021 3:06 pm there is several question: why does your file start at sketch012, where are the previous 11
Yes. There was a viral addition to one of the sketches. Gone now.papyblaise wrote: ↑Sun Oct 24, 2021 3:06 pm there is a problem in "BottomPlate Foot Fillet
Haven't used it.
Joseph Kimble
Joseph Kimble
Sure does. Thanks.TheMarkster wrote: ↑Sun Oct 24, 2021 8:25 pm Attaching to the sketch arc, MapMode = Inertial CS seems to work.
Joseph Kimble
Joseph Kimble
