Backlight not working on Mac
Brutha
Post by Brutha »
Hi All,
For some reason I can't get the backlight working in FreeCAD (not sure if I ever did in fact!): does anyone else have this issue?
There was a trick previously to get around it, by adding some lighting to the material appearance - but it doesn't seem possible in Arch using materials. It's a bit irritating to have surfaces go black as they get towards 90 degrees I find.
Any ideas?
Cheers
Brutha
OS: macOS 10.15
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
Founder
Re: Backlight not working on Mac
Post by wmayer »
Backlight is a global setting and doesn't depend on particular objects. You set it in the preferences under Viewer > 3D Viewer and there you should select another color than black.
Brutha
Post by Brutha »
wmayer wrote: Sun Oct 24, 2021 10:13 am Backlight is a global setting and doesn't depend on particular objects. You set it in the preferences under Viewer > 3D Viewer and there you should select another color than black.
Thanks, indeed, this is what I have done, but to no avail - nothing seems to change. I have quit Freecad and restarted etc, but no results. This is my setting:
Screenshot 2021-10-24 at 11.30.21.png (14.78 KiB) Viewed 1473 times
There was a suggestion from someone in the past that as a workaround you could assign a material with a degree of luminosity to it, which did work, but this is not possible in Arch materials.
Roy_043
Post by Roy_043 »
Are you aware that the Backlight color is used for the backside of faces? in other words you will not see this color when looking at solids from the outside.
Brutha
Post by Brutha »
Aha. I thought it was supposed to add some degree of "ambient" light. In the picture below, faces A and B are both the same material - I would like the lighting to be a bit more natural, and for face A to retain a more lifelike appearance even when viewed at close to 90 degrees.
Screenshot 2021-10-24 at 11.54.32.png (166.28 KiB) Viewed 1439 times
Brutha
Post by Brutha »
Hmm, I think I should be able to add an "emissive colour" to the material, it is mentioned here: https://wiki.freecadweb.org/Material as property called EmissiveColor
I tried adding EmissiveColor as a property to the arch material, but it didn't seem to do anything. Any ideas?
Roy_043
Post by Roy_043 »
Brutha
Post by Brutha »
Thanks Roy, yes, that's what I'd used before, but when I tried changing the appearance for an Arch material, that button is greyed out and so you can't set an emissive colour.
BUT - I've realised that you can set the normal colour via the material, and add an emissive colour still for each object, so there is a workaround!
It's a bit of a pain though, since if you want to change it later you might have to do it for 100's of objects. It would be nice if all appearance stuff could be done on a material rather than object basis. And from my link above, it sounds like that was the idea anyway, since the property is mentioned in the wiki.
Perhaps I can anyway write a script for this.
Roy_043
Post by Roy_043 »
Creating a script should be possible.
App.ActiveDocument.Wall.ViewObject.ShapeMaterial.EmissiveColor = (0.5, 0.5, 0.5, 0.0)
