I am trying to groove a groove in the arc (see attached picture). I selected the arc face, created 2 datum points in the center of the arc and created datum line from them. Now when I try to groove around this datumline (support axis) the groove is weirdly deformed (see attached picture).
Is it a bug or am I doing it wrong?
Grooving around datumline
- V-vzpěra2.FCStd
- (136.52 KiB) Downloaded 26 times
- After groove
- Snímek obrazovky_2021-10-24_12-34-30.png (165.93 KiB) Viewed 986 times
- Before groove
- Snímek obrazovky_2021-10-24_12-32-41.png (154.22 KiB) Viewed 986 times
Re: Grooving around datumline
Sketch001, Sketch002, and Sketch003 are all attached to generated geometry.
This has created a Topological Naming Problem (TNP) condition.
I think Pocket, Pocket001, and Pocket002 should be Pad, not Pocket operations.
Once these are corrected I think it will work correctly.
See here for further details:
Topological naming problem
Advice for creating stable models
Basic Attachment Tutorial
I have no idea how to make a pocket using a pad....
And the https://wiki.freecadweb.org/Topological_naming_problem describes a bug. And at the 7.) it describes a puzzle in Klingon language.
Sorry, I misinterpreted one of the pockets.jze wrote: ↑Sun Oct 24, 2021 12:06 pm And the https://wiki.freecadweb.org/Topological_naming_problem describes a bug. And at the 7.) it describes a puzzle in Klingon language.
None the less, I see no Klingon problem in the link.
Here is your file with the TNP mitigation addressed and an example of less complicated approach.
- V-vzpěra2-mac.FCStd
- (58.9 KiB) Downloaded 15 times
Well, you are obviously a better soldier in this war of user-hostile FreeCAD, but that doesn't solve my problem for future projects. But thanks
Greetings to the Community!
you can also do this: just set the circumference to be subtracted from the center of the corner and operate with the subtractive sweep, indicating the external edges of the "T" as a path in succession
- V-vzpěra3.FCStd
- (44.79 KiB) Downloaded 19 times
- V-vzpěra2.png (151.2 KiB) Viewed 826 times
I don't get the user-hostile bit.
And, what does it not solve for future problems/projects?
For even more reference, your original approach with no dependency on generated geometry...as described in the links I've provided:
- V-vzpěra2-mac-2.FCStd
- (107.51 KiB) Downloaded 13 times
- Snip macro screenshot-84fcd4.png (96.55 KiB) Viewed 787 times
- Shalmeneser
Sketch(000) is bad with T-vertex : impossible in PartDesign.
Should work symmetrical around YZ-plane
