After changing shape or placement of my shapebinder my master sketch that is referencing it cannot invalidate.
What I do: My final shape is symmetric on a few axis I sketched only a repeatable part created a sub object binder and than replicated it 8 times and placed where pieces should be.
Take a look at the picture.
Next I create a master sketch and reference external geometry from all this objects.
So far so good.
BUG happens when I change something for example Spreadsheet.A_ value to something else.
My mastersketch StarWheelMasterSketch can't invalidate.
See attached file.
Also if you know other way to do it instead of shape binders please give me some info.
BUG. Sub object Shape Binder and external geometry falls apart when changed.
Re: BUG. Sub object Shape Binder and external geometry falls apart when changed.
I got dizzy looking at the binders that appear to be unnecessary, so I simplified it and the spreadsheet seems ok...
- StarWheel4-mac.FCStd
- (34.31 KiB) Downloaded 20 times
Nice but I need it as a sketch or shape binder so I can further work on it with other sketches (piercing holes etc).
And I think there is still a BUG or Limitation in FreeCAD (If I'm not doing something wrong).
[Edit]OK I noticed That I can generate Sub object shape binder from it. I will try to mess around with it.[/Edit]
Umm...should be no problem making holes...
- (49.92 KiB) Downloaded 21 times
- Snip macro screenshot-d9e618.png (80.88 KiB) Viewed 1241 times
I want to stick with PartDesign as much as possible.
Unfortunately I cannot create proper ShapeBinder for pad from the array.
Fortunately I got this idea and created Shape2dView from this array it and than ShapeBinder from 2dView. And it was valid for Pad.
But is this safe, I hope I'm not losing some geometry precision ?
Why is Shape2dView or ShapeBinder needed at all?koirat wrote: ↑Sun Oct 24, 2021 1:57 pm I want to stick with PartDesign as much as possible.
Here completely in Part Design:
- StarWheel4-mac-PD.FCStd
- (122.71 KiB) Downloaded 23 times
What version you are using. I'm using 0.19 on Windows. The moment I set A_ to something different I got "Transformation Failed" on MultiTransform
[Edit]Ok on a screenshot I see you are using 0.20[/Edit]
