[Solved] Part Design Mirror
DanielSchmaniel
Post by DanielSchmaniel »
I have the element circled in red on the XY plane and I tired to mirror it to produce three other copies each at a corner of a box. The top-left mirrored element's orientation is good (vertical sketch axis) but I can't seem to figure out how to get the bottom two to point "upwards" with the same orientation as the original. How can I do this? Currently the bottom two are on the horizontal sketch axis.
Last edited by DanielSchmaniel on Tue Oct 26, 2021 12:13 am, edited 1 time in total.
Re: Part Design Mirror
Hi and welcome to the forum!
You cannot do this with a mirror, because what you want is no mirror. Use a linear pattern instead. Expressions tells you how to make this even parametric.
DanielSchmaniel
Spot on. Thank you. I played with the liner pattern before this but I guess I got frustrated before seeing that it could work. Again thanks for your help.
