help about drawing
help about drawing
hello
I am new to freecad. I tried to find a tutorial about this design but I don't know what its called arc or radius or something else
I want to create this design and want to know that if this is possible in freecad. there is multiple arc/radius in one single corner.
please anyone guide me through it ?
any help wold be appreciated.
thank you
thank you
- I only want to create outer side
- Screen Shot 2021-10-25 at 4.49.43 PM.png (136.72 KiB) Viewed 1240 times
Re: help about drawing
Are you looking for TechDraw_DetailView?
You can find several tutorials at the bottom of this page: TechDraw_Workbench
Regards / Viele Grüße
Max
Max
Does TechDraw have a way to do ordinate dimensions?
- thomas-neemann
there are many possibilities, e.g. enter points and create a bspline (very precise).
in this case i would do it this quick way if it is accurate enough.
https://www.youtube.com/watch?v=mdvJvzDhF6Y
import Draft
def makePt(x,y):
return FreeCAD.Vector(x,y,0)
xpts = [0,0,0,0.01,0.02,.05,0.11,0.26,0.55,1.06,1.81,2.78,3.95,5.28,6.72,8.22,9.74,11.27,12.80,14.33]
ypts = [18.98,17.45,15.91,14.38,12.85,11.32,9.80,8.27,6.77,5.33,4.00,2.82,1.84,1.08,0.57,0.26,0.11,0.04,0.01,0.0]
pts = []
ii=0
for x in xpts:
y = ypts[ii]
pts.append(makePt(x,y))
ii += 1
if not FreeCAD.ActiveDocument:
FreeCAD.newDocument()
Draft.makeBSpline(pts)
FreeCAD.ActiveDocument.recompute()
Is the question how to draw a curve or do ordinate dimensioning?
- thomas-neemann
if i understand my automatic translator correctly he would like to draw the curve
Hi Krupal, greetings to the Community!
With this workflow it allows to obtain the curve, the technical drawing and the coordinate table.
It was done using the "Draft" and "TechDraw" Wbs, in particular a circumference and subsequent links were created with positioning through center coordinates set in the spreadsheet.
Subsequently, the center of each circumference determined the point belonging to the curve-spline and allowed its drawing in the 3D view (using the center snap).
Everything (curve and circumferences) has been transferred to TechDraw and through the “TechDrawTools” macro the coordinate table has been created with the “Create hole table” function.
The spreadsheet, generated by the "Create hole table" function (which automatically created the coordinate table and the annotations), was subsequently linked to the spreadsheet with the coordinates of the centers of the circumferences, so that any changes made will affect all over the drawing.
Attached the file
- curve.FCStd
- (27.76 KiB) Downloaded 9 times
- curve1.png (158.4 KiB) Viewed 981 times
- TechDraw-curve1.png (148.64 KiB) Viewed 981 times
off-topic.
any code that works is good code in my book, however cannot resist from putting a slight variation of marksters code out there,
does the same - is just a bit more compact...
the passage
can be done with the one-liner
or if one prefers loops
my personal preference is the one-liner, easy to both read and write once one is used to that type of construct, and who knows, might be the fastest one (on the margin) as well
the passage
pts = []
ii=0
for x in xpts:
y = ypts[ii]
ii += 1
pts = [makePt(x, y) for x, y in zip(xpts, ypts)]
pts = list()
for x, y in zip(xpts, ypts):
pts.append(makePt(x, y))
