Misalignment on polar pattern?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I created a padded sketch for a bridge across a gap and the top of the pad is flush with the top. I then applied a draft to one of its faces to get a downward angle on the bottom face. I then applied a polar pattern for this feature but the "replicated" items have different dimensions. You can see from the image that the height is different which produces a gap so they're no longer flush with the top ring. Did I do something wrong here?
Edit: I would also add that chamfers and fillets on that bridge failed which is why I tried the draft. I haven't been able to figure out a consistent rule for when they will work or fail, so if anyone has some insight that would be appreciated too!
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- Fan cooling duct v2.FCStd
- (145.68 KiB) Downloaded 18 times
- Shalmeneser
Re: Misalignment on polar pattern?
You need at the end to PolarPattern002 with Pad003+Draft.
- Capture du 2021-10-26 18-38-37.png (27.51 KiB) Viewed 946 times
Fillet, Chamfer and Draft are rather dressups, and as such the patterns need the feature which is dressed up as well.
- Shalmeneser
└ Body001 (Body)
├ Revolution (Revolution)
│ └ Sketch005 (Sketch)
├ Pad004 (Pad)
│ └ Sketch006 (Sketch)
├ Pocket001 (Pocket)
│ └ Sketch007 (Sketch) <- picture
├ PolarPattern003 (PolarPattern)
└ Pocket002 (Pocket)
└ Sketch008 (Sketch)
- Fan cooling duct _SHALM.FCStd
- (182.11 KiB) Downloaded 18 times
- Capture du 2021-10-26 19-14-41.png (15.51 KiB) Viewed 927 times
- papyblaise
I agree Schlm , and Refine = True to finish as a one part
more advise : the best is constraint all sketches
- fan cooling.PNG (23.78 KiB) Viewed 882 times
Hello naasking, greetings to the Community!
.... you must first make the "PolarPattern" of "Pad003", then the "Draft" (in this function the "Neutral plane" must be indicated) and finally the "PolarPattern" of the "Draft".
I attach two files one is the adjustment of yours, the other a little neater in the modeling flow.
- Fan cooling duct v2-1.FCStd
- (176.84 KiB) Downloaded 19 times
- Fan cooling duct v2-fixed_up.FCStd
- (167.58 KiB) Downloaded 20 times
- comparison.png (170.08 KiB) Viewed 866 times
- Ordered.png (196.53 KiB) Viewed 866 times
- Shalmeneser
Why don't you use the same PolarPattern for Pad003 AND Draft ?
I think I understand, the order in which I include features in the pattern matters.
I agree on constraining all of the sketches. I had started with another parametric design with fully constrained sketches and spreadsheet variables, but the approach started getting way too complicated and caused all kinds of issues. I started playing with this approach and it was coming along much better until I hit this little snag. Shalmeneser's second design looks simpler still. Thanks for all of the suggestions!
Is there a certain reason why you left most sketches unattached?
Greetings to the Community!
- @Shalmeneser I didn't use them together as they can give rise to unexpected results, generally I tend to simplify the functions (patterns, fillets, bevels, etc.) that is, not to group them together, giving the function code the minimum possible data to be processed.
- No @chrisb I don't have a specific reason, but since I align sketches through the use of transformation tools and "Draft" snaps in wireframe mode (99% model in this mode) I simply don't have this need often (but the ability to bind the sketch to a face/surface is very, very important).
The point [0,0] (intersection of the Cartesian axes of the sketcher, "strategic" for my way of modeling) I always use it as a reference or origin point of the sketch / body, it almost always does (99.99%) part of the sketch itself (I never place it outside).
I always mean the body generated by "Part Design" (and everything that is used to generate it) as unique/monolithic and therefore the point of origin [0,0] or simply, for me, "pivot" I never place it at outside the belonging sketch, this allows me to position/align the sketch easily in the point of interest.
Translation permitting, I hope I have been sufficiently understandable.
A greeting
A greeting
