'nan' is not defined
ccx004
Post by ccx004 »
I am running 0.19.2 but apparently the developers do not accept bug reports on the current stable version. Anyway, I am trying to add an arc to the end of a line. I have done a few of these in the current sketch but now Freecad will not add an arc. When I try to draw it, various arcs appear all over the screen and I get errors in the report view. The errors are:
02:57:11 <Exception> CommandCreateGeo.cpp(120): Points are collinear
02:57:12 Traceback (most recent call last):
<class 'NameError'>: name 'nan' is not defined
02:57:12 App.getDocument('MagicPart').getObject('Sketch001').addGeometry(Part.ArcOfCircle(Part.Circle(App.Vector(-nan(ind),-nan(ind),0),App.Vector(0,0,1),-nan(ind)),-nan(ind),-nan(ind)),False)
02:57:12 Failed to add arc: name 'nan' is not defined
I have no real idea what this means other than NaN is often used to mean "Not a Number" although that doesn't help. It also will not draw lines, circles or squares although it will draw a hexagon.
Any advice will be gratefully received
Best wishes...
Colin
Re: 'nan' is not defined
You have created somehow a line or an arc of zero length - probably by doing some indefinite clicking. You must fix this before continuing, because otherwise the solver gets out of whack.
TheMarkster
Post by TheMarkster »
Post your file and we can have a look. Something I sometimes run into with circles is it will automatically get a tangent constraint resulting in a 0 radius. In the left panel there is an element list. I usually just go there, delete the circle, and make a new one when that happens. Something similar might have happened with the arc.
Founder
Post by wmayer »
Bug reports for the stable version are still accepted for really critical issues like a crash. For minor bugs it depends on how much work it will cause to fix them.
Founder
Post by wmayer »
After trying it a while I could figure out the procedure to create the NaN.
  • create an arc or circle where to define the point on the perimeter
  • click on an existing point of the sketch
  • move the mouse away and back to this point and click on it again
  • the third point can be again the same point or another point
Because we have two coincident points it's not possible to compute the radius because it will be infinite (hence the NaN). A string representation of a NaN is indeed "nan" that will be passed to the Python interpreter that doesn't know of such a variable and thus raises an error.
So, the function GetCircleCenter() must be fixed to determine the division by zero and raise an exception instead.
Founder
Post by wmayer »
