Additive Pipe Won't
Additive Pipe Won't
in Part PA-01-002 I wish to create a pipe elbow between Elbow Seat End Sketch and Elbow Socket End Sketch along Blend Curve which has a ShapeBinder into the part. This should be straightforward but FC pops a Fatal Error message. I can't find anything wrong with the Sketches and I checked and redid the curve and binder.
What have I done wrong this time?
- 211027 PA-00-000.FCStd
- (68.77 KiB) Downloaded 36 times
- Additive Pipe Problem.png (123.41 KiB) Viewed 1182 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: Additive Pipe Won't
I found a misalignment but that didn't fic the problem. Then I replaced the B-spline with a drawn curve.
FC still refuses to sweep either of the ends along the Path.
And - I forgot again:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- 211027 With 3-part Curve.png (123.61 KiB) Viewed 1146 times
Joseph Kimble
Joseph Kimble
Seems to work fine here.
OS: Windows 8.1 (6.3)
Version: 0.20.26201 (Git)
Hash: 9f2dd4a363053e87e1b1def0d005ed441d378796
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
- 211027 PA-00-000-roy.FCStd
- (160.55 KiB) Downloaded 32 times
Thanks, Roy. I even tried re-installing FC but that didn't make any difference.
I'll use your version!
Joseph Kimble
Joseph Kimble
Why do you have the pipe profile at both ends? you only need it once, then select each edge.
I think you have pointed out why I couldn't get FC to sweep. It's the clicking sequence. I'll have a play with that.
Darned annoying really! I have swept quite a few things without trouble. It's just that today ... ...
Joseph Kimble
Joseph Kimble
If I recompute Roy's model the pipe vanishes.
OS: macOS 10.16
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
It sort of works if I redraw the the B-spline. However, the result fails CheckGeometry. Roy's model fails as well, but with different messages.
- 00-000_cb.FCStd
- (90.6 KiB) Downloaded 26 times
Here, I get a valid solid.
I changed 2 things :
- I inverted the order of the 2 circles in one of the profile sketches
- I moved the normals sketches, used by the blendcurve path to the border of the 2 profiles, so that the sweep path is the shortest / steepest.
To me, this last rule should be applied as often as possible, to avoid self-intersections in sweep.
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.26209 (Git)
Hash: 13cd1c23eca38683420ce1237d6b56f345366905
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
I forgot about that trick. I have had that problem before. Grrr!
That's a good one. Thanks.
Joseph Kimble
Joseph Kimble
