[solved] I have a problem with the angular dimensioning in draft.
- thomas-neemann
am i making a mistake or is there a work around etc ?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26155 (Git) AppImage
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
edit
also here
Version: 0.20.26202 (Git) AppImage
Hash: ca6d49d080dea0abc23d954743eca7c46f33469b
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
edit
also here
Qt version: 5.12.9
OCC version: 7.5.3
Last edited by thomas-neemann on Thu Oct 28, 2021 11:11 am, edited 1 time in total.
- thomas-neemann
Re: I have a problem with the angular dimensioning in draft.
here is a workaround. if you turn the plane in which the dimensions are located into a main plane, it seems to work.
I consider this behavior to be dangerous because it may not be noticed and this may result in damage or a delay in deadlines.
https://www.youtube.com/watch?v=T13pRBpEOg0
I think this is a bug. In the image in the first post the big angle of 319,39 is correct and the small angle of 30.51 is wrong.
In the properties of the angle they both have a first or second angle of 52.13 and the other angle is different.
I did the dimensioning several times and each time the same result
- thomas-neemann
thank you willem for your cooperation. the problem also seems to occur if only the view is rotated between the creation of the geometry and the dimensioning.
https://www.youtube.com/watch?v=GS07dgbPNZY
Qt version: 5.12.9
OCC version: 7.5.3
edit
I have not yet been able to reliably reproduce it, sometimes everything is correct and sometimes everything is not.
- thomas-neemann
with 19.2 I managed to reproduce the error twice in a row. before and between the two tests I deleted .FreeCAD and .config / FreeCAD
here are the uncut videos
https://www.youtube.com/watch?v=FioDFiTUVn8
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Qt version: 5.12.9
OCC version: 7.4.0
AFAICT this problem occurs if end points of the selected edges are coincident with their intersection. The attached file should fix the issue. It should be placed in:
<install_folder>/Mod/Draft/draftguitools/
- gui_dimensions.py
- (27.74 KiB) Downloaded 27 times
Hi Roy_043, greetings to the Community!
Many thanks (!) For sharing / suggesting the solution (it was a big flaw), but I don't understand why the correct file has not yet been included in the (?) Compiled distributions.
The attached images demonstrate (using TechDraw) the effectiveness of the correction of the defect and then the extreme versatility in 3D, you simply need to align the work surface and the "game" is done.
- test.FCStd
- (14.93 KiB) Downloaded 27 times
- check_with_TechDraw.png (157.49 KiB) Viewed 1355 times
- 3D_dimensions.png (220.19 KiB) Viewed 1355 times
- thomas-neemann
Thanks alot. I am very happy. I tested it and couldn't find any more problem.
here is the path for ubuntu systems
OS: Ubuntu 21.10 (XFCE/xubuntu)
Version: 0.19.
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
