When I try to add a pocket to the model it adds and extra material item in an odd spot. Anyone want to take a look and see what I am doing wrong? Or is this just a bug in Freecad19? I just uploaded the lastest version of freecad19 and it still shows up.
Thanks,
Troy
Pockt adding extra bug
- freecad19 error.png (12.53 KiB) Viewed 564 times
- TRP3 Steering wheel V014.FCStd
- (845.79 KiB) Downloaded 12 times
Re: Pockt adding extra bug
If I fully recompute, it stops recomputing at Pocket010 saying "Result has multiple solids". Which isn't supported
Also your sketches are sometime under-constrained, sometime over-constrained.
You should first fix your model then see if problem still exists.
EDIT : was with 0.20. On 0.19 it stops at Fillet saying "Resulting shape is invalid". Much problems in the file...
EDIT2 : just looked the dependency graph ... All sketches are linked to respective previous features, which makes your model very prone to fail due to topological naming issue.
- Shalmeneser
* You should support all your sketches upon XZ-plane.
* Recompute then Part_CheckGeometry on TRP3_Steering_wheel_V014_1_.Pad001 (Pad001) shows problems.
* First pad could be circular
I went in and fixed all that were not constrained that fixed it. Thanks.
