PolarPattern appears to work but not visible
- papyblaise
Re: PolarPattern appears to work but not visible
using the chamfer function, the result is excellent, and just as robust as a poorly made Loft
- drum.PNG (8.24 KiB) Viewed 1782 times
- drum.FCStd
- (109.84 KiB) Downloaded 40 times
I cannot get either a chamfer or a fillet to work.
If I select a single joint, it succeeds. But if I select two or more, it fails with "Recompute failed! Please check report view". (BTW, I've never understood this message, since I have to be looking in the report view to see it, and there is no additional information there.)
Set Refine = True for the previous feature when fillet or chamfer fails. Sometimes that can make it work.
Yes, that's why I was avoiding them. This is a cut down example. I wanted to experiment with the number of legs; so both the topological naming problem and tediousness are an issue.TheMarkster wrote: ↑Fri Nov 12, 2021 9:29 pm I usually save the fillets for last because they are quite fragile to topological naming and because they are fairly simple (if a bit tedious) to do. Another train of thought is to do them very early in the process.
I can't figure out how you accomplished that. I'm guessing the datum plane is to mirror the fillets onto the bottom (I don't actually need or want them there), but I don't understand the multitransform to add the fillet. Did you create two, one on either side of a single post, and then polar pattern?TheMarkster wrote: ↑Fri Nov 12, 2021 9:29 pm You can use a multitransform to add the fillet, polar pattern it, and then mirror it.
In the images below, when I try to add them individually, I have trouble -- one extends clear to the bottom of its leg, and when I try to add the 8th one I get a recompute failed error.
If I try to add a pair of fillets, one on either side of a single post, it fails for 2 of the posts, but succeeds for either of the other two. If I then try to polar pattern one of the ones which succeeds, in one case I get a "Transformed: Result has multiple solids. Only keeping the first." error, and in the other it appears to succeed (no errors) but the 3d display is empty except for a point.
Yes, the datum plane serves as the mirror plane for the fillets on the bottom. You can lose the mirror if you don't want it. Expand the MultiTransform and delete the mirror. You can then also delete the datum plane.
Set SpoolTop Refine = True. Make the Fillet visible to see which edges I filleted:
The MultiTransform tool is very powerful, but it's somewhat complicated to use, especially for a beginner. Linear arrays of polar arrays, for example, would be more intuitive.
If I create a pair of fillets on either side of a single post (one of the ones that works)...TheMarkster wrote: ↑Sat Nov 13, 2021 5:31 pm Set Refine = True for the previous feature when fillet or chamfer fails. Sometimes that can make it work.
If I then set refine=true for the fillet, I get an image that appears to completely fill the empty space on either side of the post.
If instead I set refine=true for the "SpoolTop" feature prior to the fillet (after creating the fillets), then hit recompute, I get a recompute failed error.
Can you include the file you used to produce this? I can't reproduce it. I'm fairly familiar with multi-transform.TheMarkster wrote: ↑Sat Nov 13, 2021 5:47 pm The MultiTransform tool is very powerful, but it's somewhat complicated to use, especially for a beginner. Linear arrays of polar arrays, for example, would be more intuitive.
I already attached the file.
https://forum.freecadweb.org/download/f ... ?id=169634
I'm able to do a full recompute with this version, no errors.
OS: Windows 10 Version 2009
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I've been testing your model and finally was able to make the chamfers with a pad and two subtractive lofts. It is a lot more laborious than with the chamfer feature, although also further from TPN, I guess.
I modified some things that maybe they are not necessary. Changed the refine to true in all features. Modificied deviation property to 0,1 or 0,05 in sketches and body. Deleted sketch "Sk_BtnSupport". One I consider important, sketch "Sk_TopSupport" had external references to Geometry of a feature, changed to external reference to first scketch "Sk_Spool_Base" to avoid TPN issues posibles. Attach the file, I hope it helps.
Greetings.
Greetings.
- PolarPatrn_1_2.FCStd
- (248.76 KiB) Downloaded 23 times
@TheMarkster Sorry I didn't get your file the first time.
If I start with my original and do the following:
Delete Supports
Delete Proto_Support
Delete Sk_BtmSupport
Delete Sk_TopSupport
The terminal feature is then SpoolTop
If I look at that image as a wireframe, I see this:
If I start with your file, and do the following:
Delete MultiTransform
Delete Fillet
I see this:
Can you tell me how you got back to the starting point for your file, from my original?
Note the difference on the inside rim of the wireframe where the fillets start.
On yours, there is no line connecting the inside rim arcs on either side of the post sticking out.
On mine, there is a line crossing over connecting the two arcs.
I don't know if this has anything to do with the problems I'm having or not, but it seems suspicious.
BTW, using the PDWrapper macro worked here as well.
Delete Supports
Delete Fillet
I see this:
