PolarPattern appears to work but not visible
TheMarkster
Re: PolarPattern appears to work but not visible
Post by TheMarkster »
If it were only a rendering issue a mesh created from the body would show the missing material, but it doesn't. It is some sort of OCCT bug related somehow to the coplanar face issue / seam line issue we see all the time.
heron
Post by heron »
I found out what was causing the issue.
When making the Additive loft, change the selection order of the two sketches and works fine.
garya wrote: Sun Nov 14, 2021 4:18 am Reported as issue #0004788
I attach the file. Maybe you should include the information in the bug tracker.
Cheers.
PolarPatrn_1_A.FCStd
(149.92 KiB) Downloaded 29 times
garya
Post by garya »
@heron
Not sure how I missed the last part of the discussion...
Anyway, thanks.
Unfortunately, that fix is specific to that drawing.
Changing the order of the loft has no effect on the file below.
PolarPatrn_5.FCStd
(220.8 KiB) Downloaded 36 times
heron
Post by heron »
Sorry, I did not aware of this response.
garya wrote: Tue Dec 14, 2021 1:08 am Unfortunately, that fix is specific to that drawing.
Yes, you are right. I checked the file, the problem continues and the trick does not work.
Regards.
Post by Kunda1 »
Ticket migrated to GH issue #6285
bumping for re-check prior to v0.20 release
Fat-Zer
Post by Fat-Zer »
Is this still an actual problem?
I failed to reproduce the issue on a recent git with any of the provided examples. Simple recalculation of the model seams to produce a correct result in each of the provided files.
OS: Gentoo Linux (Trinity/trinity)
Version: 0.21.0.32200 (Git)
Build type: Debug
Hash: 1a0801a23f917f534d4dabe8c956df4cd206e2a2
Python 3.11.2, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.5, OCC 7.7.0
Locale: Russian/Russia (ru_RU)
Installed mods:
  * slic3r-tools
  * BIM 2021.12.0
  * ExtremeProDark 2.7.0
  * Glass (Disabled)
Fat-Zer wrote: Mon Mar 06, 2023 4:52 pm Is this still an actual problem?
Thanks for testing!
I confirm that it is fixed - probably in OCC, and have closed the issue.
