I had quite the challenge to make a bayonet fitting in FreeCAD. The Bayonet fitting is easy to make with a rotary milling cutter. As you can see below in the supplied STEP file.
- bayonet_interfac_bottom.png (75.4 KiB) Viewed 2551 times
However creating a model that fits was quite difficult with the Part Design workbench. Since I need to sketch on both on a cylinder, but also keep the angles in check. One option was to use the curves toolbox then I could draw curves on the cylinder, but making sure the angels were correct or import them in the sketch would almost be impossible.
In the end I did the following:
- Make a sketch with each piece on a new datum plane,
- Do a revolve for the appropriate angle.
- Then add another sketch with revolve until the shape is finished.
- For the other 3 items, do a polar pattern around the vertical axis.
- In order to make the curved shape to fit the metal I made fillets on the protruding ends.
However, I couldn't make fillets in the enclosed corner. Fortunately I could live without that.
With the following result:
- bayonet_interface.png (53.77 KiB) Viewed 2551 times
This actually fitted after 3D printing the part.
I can imaging there would be an easier method and I would like to here what a good method would look like.
Any suggestions?
